What psi for 265/70R17?
Discussion in 'Wheels & Tires' started by TacomaGRG, May 26, 2010.
  1. May 26, 2010 at 5:33 PM
    TacomaGRG
    TacomaGRG [OP] Well-Known Member
    Greg
    Danvers, MA
    09 SR5
    Westin Stainless Bull Bar Flowmaster 50 Dual Exhaust 17" FJ Cruiser Wheels Socks Devil Horn 3rd Brake Light Cover STK Pro Rack Carriage Works Black Billet Grille w/Devil Horns Stubby Antenna Avid Rocker Guards Rear Leaf TSB Rear Bilstein 5100s Front Bilstein 5100s @ 1.75 AFE Air Filter
    What psi do you guys recommend for 265/70R17?
  2. May 26, 2010 at 5:58 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Too many real life factors to tell you exactly what to run. If you want a true measurement, you'll need to do the chaulk method. (Covered in the sticky in this section labeled "What psi should I run").
    The basics is draw a chaulk line across the tire, drive 100 yards straight and see where the chaulk has worn off. If its in the center, let out air. If its on the outside, add more air. Repeat until it wears evenly. (if it only wears on one side, you have an alignment issue).
  3. May 26, 2010 at 9:31 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    35psi. But yeah, if you really want to dial it in perfect you gotta chalk test; easy, takes about 20min.
  4. May 26, 2010 at 9:39 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    i found 35 psi too high for me. running 29-30 psi. caveat that with, i just did the chalk test yesterday, so i'm still seeing how this pressure feels on the highway.
  5. May 27, 2010 at 7:35 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks for the info guys. I have to try that chalk test.
