What psi should i run
Discussion in 'Wheels & Tires' started by Madams, Aug 25, 2011.
  1. Aug 25, 2011 at 1:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    First off, no need to be disrespectful, keep that shit to yourself. If you can't debate on the internet, then don't...
    What I was getting at is you can't use it as a guideline. You're better off using the door jamb as a guide rather than the max pressure on the tire. If you use your logic and you're running D range tires, they have a max pressure of around 80 psi IIRC, that would mean you'd be running 75 psi in your tires. Realistically, you need about 1/2 that.
  2. Aug 25, 2011 at 1:03 PM
    Pugga
    Massachusetts
    Sorry, Brock, got a little excited :eek:
  3. Aug 25, 2011 at 1:16 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    You have good points-I apologize for gettin on ya like I did. I was always under the impression that you needed a minimum of air to consruct the tire (like 10lbs off)
  4. Aug 25, 2011 at 1:19 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    no the max PSI rating in a tire has nothing to do on what the psi should be at.
  5. Aug 25, 2011 at 1:31 PM
    Pugga
    Massachusetts
    No worries :thumbsup:
  6. Aug 25, 2011 at 2:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Well Done! Both of you! :)
  7. Aug 25, 2011 at 5:15 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Ha hey Chris:) naw I gotta give it to Pugga there-even after my grouchy response, he still had tact. As soon as I saw that I had to correct myself.
