What psi should i run?
Discussion in 'Wheels & Tires' started by TacoTRD420, Sep 10, 2009.
  1. Jun 22, 2017 at 4:14 PM
    #201
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    33lbs all around seems to be the happy medium. Any higher on P rated tires gets a little jarring, especially on the back end. Any lower and you start seeing a decrease in mpg.
  2. Aug 3, 2017 at 12:58 AM
    #202
    Baggerboy11
    Baggerboy11 Member
    CA
    I run 40psi on my Toyo A/T 285/70/17
  3. Feb 21, 2018 at 11:24 AM
    #203
    tacocody13
    tacocody13 Well-Known Member
    cody
    2004 taco, well loved
    toolbox and weight reduction
    i run 33 psi all around. noticeable wobble reduction and slight improvement at the pump, but fuel savings are marginal
  4. Feb 21, 2018 at 12:07 PM
    #204
    NMTrailRider
    New Mexico
    I noticed a big difference in mpg when I went from several years at 30 to now 35psi. Definitely a bumpier ride, but much less resistance on the road. I air down a little in the winter (32psi).
  5. Feb 21, 2018 at 9:41 PM
    #205
    tacocody13
    cody
    what mods are you running. maybe my truck is lighter, but 33 is my magic number
  6. Feb 21, 2018 at 10:41 PM
    #206
    NMTrailRider
    New Mexico
    No mods. And I'd agree, 33 is the sweet spot.
  7. Feb 21, 2018 at 11:00 PM
    #207
    tacocody13
    cody
    ive got moderate weight reduction going. anything that wasnt necessary, nailed down or dangerous to remove (damn airbags) is gone, safely tucked away in some boxes should i ever want them again.
  8. Mar 14, 2018 at 3:58 PM
    #208
    fishmando
    fishmando Well-Known Member
    I have a 3rd gen 6MT with the 3.5, and since I'm mostly doing short drives, I see aweful milage! (Stock too!)
  9. Mar 15, 2018 at 12:53 PM
    #209
    MtnLessGoat
    MtnLessGoat Well-Known Member
    So. FL
    The Warthog - 2018 TRD OR DCSB in Cement
    I am there with you. My commute is 5.5 miles from home to work down one road - a very busy road nonetheless with tons of lights. I have a tonneau cover, changed factory exhaust to cat back and install an CAI. I never turn on the A/C and my MPG doesn't increase from 15.9 - 16.5. I have no load on the truck and no hard acceleration. PSI is at 35. dunno to increase to 37PSI.
  10. Mar 15, 2018 at 12:58 PM
    #210
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    In town that’s not horrible. What do you get on the highway?
  11. Mar 15, 2018 at 2:31 PM
    #211
    MtnLessGoat
    So. FL
    Hwy is about 20.5. I thought city would improve with all the tweaks I've made
  12. Mar 15, 2018 at 3:45 PM
    #212
    NMTrailRider
    New Mexico
    In theory, when installing a larger than OEM tire of the same load rating, would one put more or less PSI in it than the door sticker suggests? My gut says more, but I'm really not sure?
    I'm not asking "what's best". I'm asking with regard to having the larger tire pressure "match" the smaller tire, so as to maintain the "factory feel".
    Danno1985 likes this.
  13. Mar 15, 2018 at 5:05 PM
    #213
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    That’s good, when my DCSB 4.0 was stock best I got was 16-17. Now that it’s got 35s and armor it’s 11-12.
    My little AC 2.7 gets 22.5 best tank
  14. Mar 16, 2018 at 1:05 PM
    #214
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Michelin Defender M+S at 245-75-16 ... does well with 35 psi to 36 psi @ front & rear.
  15. Mar 16, 2018 at 2:58 PM
    #215
    freedomriding
    freedomriding FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    I did a media project for Michelin tires and they said you don't have to go by what the tire is rated at, as stated on the sidewall, but what you're vehicle specifically states on the door jam placard. 32-35psi is perfect, especially if you're running E load tires since it'll help soften them a bit. Just my .02
  16. Apr 11, 2018 at 10:15 AM
    #216
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    I'm running BF Goodrich KO2s in 31X10.50r15, load range C on 15x7 rims. Typically I've found 35psi is a decent starting place, but after doing some chalk testing these seem to make the best contact at 29 or so - at 35 they were crowning. The tread patch seems to be quite a bit wider than the Firestone ATs in the same size I had before, so for these particular tires the placard in the door jamb was pretty much spot on. Makes sense, considering this truck is pretty damn light for what it is.
    Update: After looking at Discount Tire's Load/Inflation chart which seemed to indicate these tires should be filled at 40, I emailed BF Goodrich and asked for their take on it. They got back to me the next day, and confirmed that in order to retain the same load reserve as the stock P-rated tires, as well as to avoid premature wear or failure caused by excess heat from underinflation, they also recommended 40psi. So, that's what I'll be running for the foreseeable future. So far the gas mileage is 1-2 mpgs better (predictably; the truck just feels like it rolls better, tires are quieter, and it feels less spongy cornering and braking. Man, the ride is punishing over expansion gaps and potholes, but I'm getting the sense that is the tradeoff I've made.
    Area51Runner likes this.
  17. Apr 28, 2018 at 5:09 AM
    #217
    taco pops
    taco pops Well-Known Member
    Russ
    West Michigan
    2016 black SR5 Tacoma DCSB
    Side Steps, Tonneau cover
    i am not sure if this has been covered but here we go. what tire pressure should i run pulling a 5500 trailer? I don't have a load equealizing hitch but do have the tow package.
  18. May 23, 2018 at 10:43 AM
    #218
    Nateclimb
    Nateclimb Well-Known Member
    UT
    15 Inferno Pro SC'ed
    I have the same truck and was wondering the same thing, I have 265/75r16 ProComp AT Sports.
  19. May 23, 2018 at 2:30 PM
    #219
    NMTrailRider
    New Mexico
    Only thing I can think of is if that truck came with load range E tires. But that sure seems unlikely. Did Pros come with E's?
  20. May 23, 2018 at 2:37 PM
    #220
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Ive messed around with all kinds of pressures. And now run 29psi. That's what's on the b pillar sticker. It's seems to be the best number. Running E 265/75/16.
    Update: I was getting some uneven wear at 29psi. after about 10k miles there was a lot vibrations from the shoulder lugs. I bumped up pressure to 32, rotated tires and after about 5k seem to be wearing much better.
    JStarr and ranzulu like this.
