What psi should i run?
Discussion in 'Wheels & Tires' started by TacoTRD420, Sep 10, 2009.
  1. Mar 5, 2023 at 11:20 AM
    #321
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    The “tire pressure.com” version reads a chart, and doesn’t interpolate. The “tire-size” one does a calculation to interpolate and produces a more accurate answer.
    Remember to check if your original tires are “P-metric” or non-P. It’s on your door jamb.
  2. May 2, 2023 at 7:07 PM
    #322
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Weight per tire will lower your mpg’s. Higher the rating usually is heavier tire. More ply means more ridgid sidewall which is huge in determining the handling characteristics on the road. I had these whimpy 2 ply Duratracs on my last truck (Canton AT4) they all were smitten with and they had atrocious roll to them and sucked in the rain (the genius idea to put an auto locking rear diff on that model didn’t help) and I would regularly break loose the rear on sharp turns mildly accelerating. I think some truck companies try to accommodate or even lure people to their rigs by putting on an AT tire but they don’t always hit the mark. The GY Territory AT’s that came on my taco are far superior to the Duratracs being a smoother ride and more ply sidewall they can handle turns without too much roll and wet traction is good. They’re a solid choice for all around driving. Those Michelin LTX defenders are one of the best truck tires out there. They are based more for highway driving but have all others beat in the wet, snowy, icy conditions. Lots of very loyal owners use them exclusively on all their rigs. I think going up to an LT tire will feel good and have a solid feel but really not needed in these small trucks. They are heavy. To the point of 10 plus pounds more per tire. The BFG KO2 that everyone likes to throw on their rig is a 60 lb 10 ply beast and one of the best AT tires out there. As per my next set I’m going with the Toyo AT3 which make a 4 ply XL rated tire and a heavier 8 ply E rated tire. The XL option for the small trucks is plenty and they have superior wet traction for my Western WA roads. They have 3 peak snow rating too. Another way to get better wear is siping. Siping can give you great wear and traction. As far as PSI I was always told to first start with the vehicles recommended pressure and don’t go above or below 5 pounds either way as long as it doesn’t exceed the max cold pressure of the tires
    Flori-duh Taco likes this.
  3. Jun 25, 2023 at 7:23 AM
    #323
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    265/75r16 I run cold at 30 in the back and 32 in the front to account for front end weight. Front never gets over 34/35psi, warm.
    I think it all depends on where/how you drive.
    I can't see running no 80psi like my tire recommends. At least not for anything that I do. Might chip a tailbone.
    Rock climbers run them real low like 14psi range.
  4. Jun 26, 2023 at 7:30 PM
    #324
    BC Hunter
    The "80 psi" on your tire is a "maximum allowable," not a "recommendation."
    Unless you are doing something very odd with your truck, use this to decide on the normal cold temperature pressure you set your tires at.
  5. Jun 27, 2023 at 3:51 AM
    #325
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Ya. Poor choice of wording on my part but you catch my drift. That's a lot of F'n pressure.
  6. Jul 14, 2023 at 8:27 PM
    #326
    davep2012
    davep2012 Well-Known Member
    Dave
    2012 Silver Tacoma
    Weather Tech floor mats and Marathon Seat Covers
    I'm running Yokohama G056's, stock tire size, great tire if we didn't have any snow here. Lousy when there is snow or ice on the ground unless I put it in 4wd, so may be a factor of being a truck with a light rear end and not so much the tire. I've always kept tire pressures on all of my vehicles between 30-32 psi and have always had even tire wear.
    It drives me nuts when technicians crank the tire pressure up to 40-44 psi when you take your vehicle in for service.
  7. Aug 25, 2023 at 10:36 AM
    #327
    ShadowHog
    ShadowHog New Member
    Zach
    2018 Metallic Grey SR5 TRD OFF-Road
    I am running Nittos ridge grapplers on 265/70R16 and been running them at 38 psi. I am wondering if anyone is running stock like myself and what psi is working best for you or if I need to do the chalk test.
  8. Apr 30, 2024 at 7:11 AM
    #328
    Pac0Taco
    Pac0Taco New Member
    Patrick
    Ottawa, ON
    2016 Black SR5 4x4
    New to trucks and just got my 2016 Tacoma SR5
    it came with brand new BFGoodrich Advantage T/A Sport LT
    do these qualify as LT tires that need more pressure?
    how can i tell if its actually p rated?
    Stock size is 245/75/16 and call for 32psi all around
    new tire is also 245/75/16 T load rating 111
    The dealer inflated to 32 all around
    based on these threads though, it seems not only should i have higher pressure in the first place
    but i might need even higher because of the new tire style just to match the placard psi equivalent
    suggestions / recommendations welcomed
    Thank You
  9. Apr 30, 2024 at 8:51 PM
    #329
    BC Hunter
    Scroll up about 4 posts and use the link to the pressure calculator.
  10. Apr 30, 2024 at 9:10 PM
    #330
    Bishop84
    Bishop84 Well-Known Member
    The tire name is needlessly confusing.
    T is the speed rating, 111 is the load rating. It's a standard load tire, 32psi is perfect.
    If you ever think a tire is E or LT rated, look at the tire size, it should start with LT245/75R16
    Next the max psi on the tire will say 80psi, whereas your tire is 44psi max.
  11. May 1, 2024 at 6:04 AM
    #331
    Pac0Taco
    Pac0Taco New Member
    Patrick
    Ottawa, ON
    2016 Black SR5 4x4
    thanks for the explanation on verifying LT tire
    80 vs 44 is a good one to look at
    also very confusing that the manufacturer would include LT in the tire title
    would you recommend a slightly higher psi for better MPG(L/100KM)
    from what I have seen ~10% would be good and that would be ~35PSI
    while 35 seems the most common (when car calls for 32)
    I am seeing people use between 33-38
  12. May 1, 2024 at 7:54 AM
    #332
    Bishop84
    32 cold warms up to about 35psi or more during the day and highway driving.
    If you start at 38psi you can actually go over the 44psi max depending on temperature swings.
    I’d say only go higher if you’re towing or hauling.
    35 cold is as high as I’d go normally.
  13. May 1, 2024 at 8:08 AM
    #333
    Pac0Taco
    Pac0Taco New Member
    Patrick
    Ottawa, ON
    2016 Black SR5 4x4
    Thank you sir
    I will try 33-34 and monitor how high it goes @ hot
    I will try to find a value that does not pass 38 @ hot
    Bishop84[QUOTED] likes this.
  14. May 3, 2024 at 9:09 AM
    #334
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    E rated tires require more pressure than SL tires for a given load. It is counter-intuitive, I know, but it is true. Stock tires are SL. The calculator shown above is pretty accurate if you enter the tire's load rating correctly. You can also go to the tire's manufacturers website. Often they will have a load/pressure chart for each tire and size. If you use the load max indicated on the door jam placard for the oem tires and check the chart for the same load - you will get the 'proper' tire pressure for the tires you are running.
    BC Hunter likes this.
  15. Nov 14, 2024 at 3:39 PM
    #335
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Can you kindly provide the LT metric load formula? I cannot find any tables that give you load capacity under 35 PSI, and I don't think the weight per PSI moves linearly, so if you had the underlying formulae I would appreciate it! (Trying to see load carrying capacity of LT275/70/118 125 load at 30-34 PSI -- at 35PSI it's 2,070 pounds, but I cannot find anything about what's below that)
  16. Nov 14, 2024 at 3:52 PM
    #336
    trexgrrr
    trexgrrr Well-Known Member
    I run my 295/70/17's at 38. When I drive on the freeway to a campsite fully loaded, I'll bump it up to 40 in the front, 42 in the rear. On the trails i'll drop it down to 22.
  17. Nov 14, 2024 at 6:32 PM
    #337
    BC Hunter
    That's because you aren't supposed to run LT tires at under 35 psi.
  18. Nov 14, 2024 at 6:51 PM
    #338
    TacoRancher
    Houston
    I think that’s right. That said, 1-2 psi below will likely be fine, but wanted to calculate the actual load before I messed around with it.
  19. Nov 24, 2024 at 11:06 AM
    #339
    MississippiPI
    MississippiPI Well-Known Member
    Jimmy
    All over the Great State of Mississippi
    2018 SR5
  20. Nov 30, 2024 at 10:37 PM
    #340
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Sorry for the late reply.
    I rarely come by TW anymore...
    You're right...the charts suggest it doesn't follow a linear slope.
    I extrapolate a value from the lowest psi range available. Caveat emptor...
