What psi should i run?
Discussion in 'Wheels & Tires' started by TacoTRD420, Sep 10, 2009.
  1. Dec 5, 2024 at 4:20 PM
    #341
    eurowner
    eurowner Duke Sky
    Scoty
  2. Sep 27, 2025 at 11:57 AM
    #342
    ruddytaco
    ruddytaco Well-Known Member
    Shawn
    2001 Tacoma 4x4
    Useful information
  3. Oct 5, 2025 at 9:37 AM
    #343
    DesertRatR
    DesertRatR My favorite dog is what I got.
    Southern AZ
    2025 TRD 4WD Off-Road White
    New 2025 Taco TRD OR with BFGoodrich Trail Terrain T/R tires 265/70R17. The door placard indicates 30 psi. I don't think that is right for these tires. The options for setting the warnings are 30, 32 and 35 psi. I am looking for recommendations for street pressure. The tiresize.com calculator didn't help, unless I am using it incorrectly.
  4. Oct 5, 2025 at 10:16 AM
    #344
    Bishop84
    Bishop84 Well-Known Member
    30 is bang on for the standard load trail terrains, if you go 35 it will have less edge wear but maybe a bit better fuel economy. I'd run 35 just to get a bump in fuel economy.
    Because you live in AZ you dont have to worry about cold traction, but anyone else I'd suggest 30psi winter.
  5. Oct 5, 2025 at 10:56 AM
    #345
    DesertRatR
    Southern AZ
    Thanks for that. Maybe I am misunderstanding the warning notifications. If I were to set the tire pressure at 30 I'd be getting a lot of warnings. What am I missing?
