What psi should i run?
Discussion in 'Wheels & Tires' started by TacoTRD420, Sep 10, 2009.
  1. Apr 9, 2012 at 10:10 AM
    #81
    Syntonization
    Syntonization tAKoma Godfather
    Jeremiah
    Anchorage, AK
    09' TRD Sport dbl cab long bed
    Cooper Discoverer ST MAXX 295/70/17. Tuff Wheels 17x8 -13 Offset. Front Suspension: Fox Racing 2.5 Series Extended travel shocks w/ Eibach coil-overs, Total Chaos UCA's. Rear: Dakar Leaf Springs, Fox Racing 2.5 Series Long travel shocks. Superbump Stops. Cab mount frame chop. BruteFab frame sliders. Pelfreybuilt Front bumper, Hi-Clearance Rear w/swingarm and table. Color matched BRM! Superwinch Tigershark TS9500 SR. Morimoto 5Five FX-R Stage III HID Projector retrofit 6000K. Rigid DOT Fog lights, 20" light bar, dually ditch lights. 6500 lm LED underbody rock lights. Fog lights on any time MOD. K&N 77 Cold Air Intake. Flowmaster American Thunder CAT back dual exhaust. CompuStar 2 way remote start w/ 2 stage alarm and keyless entry. White under hood LED strip lighting, with automatic hood pin on/off switch. Dynamat & Dynaliner sound deadening in doors & cab. Kenwood DDX574BH Head unit with Maestro OBDII interface. Rockford Fosgate Punch 5 ch amp with Punch Component tweeters, woofers & sub. USB charging/data ports in blank plug under head unit. Instrument cluster, red and white LED's replacement. Backlit 4x4 selector switch. Anytime on/off Rear-view mirror back up camera. Uniden PRO520XL CB w/ co phased ATT's. Toyota Hood Protector. Coverking Neoprene black w/ red center seat covers. Color matched Devil Horns grill emblem.
    That's what I thought too, but today the stealership told me that my 09' sensors will only go up to 35 psi. Was she on crack, or what?
  2. Apr 9, 2012 at 10:14 AM
    #82
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Crack
    My '09 is currently at 36 PSI and the tires were originally at 40 PSI , no warning light
  3. Apr 9, 2012 at 10:15 AM
    #83
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Those tires are e rated right? If so i've got the same. Are you saying bfg advised running a higher pressure in the rear with an empty bed? I would think you'd want the higher psi up front because of the weight of the engine. :confused:
  4. Apr 9, 2012 at 10:16 AM
    #84
    Syntonization
    Jeremiah
    Anchorage, AK
    Thanks guys!
  5. May 12, 2012 at 9:00 PM
    #85
    nwb3160
    nwb3160 Well-Known Member
    Nick
    Cartersville, Ga
    2008 Tacoma TRD Sport
    5100s OME 885 2009 tail lights 6000K HID Pioneer 4400 DVD Viper Alarm/Remote Start Avid Offroad Bar/Side Steps Wet Okole Seat Covers Husky Floor Mats Toyo Open Country MT 265/70R17 BANKS Monster Exhaust Ultraguage
    I just installed the toyo mud terrains, it says 80psi max. the tire shop only put 41psi in them. how should I know what the correct psi should be so the wear evenly?
  6. May 12, 2012 at 11:27 PM
    #86
    OZ-T
    Peter North
    British Columbia
    Chalk test
    My E rated LT tires are 80 psi max and I run them at 36
  7. May 13, 2012 at 10:22 AM
    #87
    nwb3160
    Nick
    Cartersville, Ga
    ha, I have 65 in mine right now
  8. May 13, 2012 at 11:52 AM
    #88
    OZ-T
    Peter North
    British Columbia
    WAY too much
  9. May 13, 2012 at 12:52 PM
    #89
    nwb3160
    Nick
    Cartersville, Ga
    i deflated to 46 and will probably drop to 42 later. is there no tool i could buy to do the same thing as a chalk test?
  10. May 13, 2012 at 1:23 PM
    #90
    OZ-T
    Peter North
    British Columbia
    Yes
    Chalk
    Flyinbrianbmx likes this.
  11. May 15, 2012 at 1:18 AM
    #91
    Hard Luck
    Hard Luck Active Member
    Pete
    San Diego
    07 Tacoma TRD Sport
    lift, cold air intake, jba headers, Boarla, 18" XD wheels, 33" Toyos, billet grille, in cab 110 outlets, 400 watt all the time, bed lights, fog lights anytime
    I have 33" Toyos on 18" wheels.. I was running 40 psi all around from the tire shop, my truck rode like a fork lift! I googled and looked at all the forums and everyone had a different psi, I did the chalk method and the lines looked the same from 28 psi to 35 psi!!! I called Toyo and talked to the tech department. He looked up the weight of my truck and wheel size and tire size and said 29 psi all around would be perfect, so thats what im running at, rides great again. I did have to reset my TPMS because of the bigger wheels..
  12. May 15, 2012 at 10:52 AM
    #92
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    These are P rated or LT?
  13. Jun 28, 2012 at 8:19 AM
    #93
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Hmm...I was running 42psi in my 265/75/16 Yokohama Geolandar A/T-S, D rated tires (65psi max). Couple of days ago the dealership aired them down to 34psi according to the door jam.
    Time to do the chalk test.
  14. Aug 22, 2012 at 9:59 PM
    #94
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Just randomly dropping in here...
    Actually you can mimic the chalk test with masking or painter's tape. It does the same thing, but takes longer for the result since you have to wait for it to wear off. I found it a bit easier to do since the chalk rubs away really fast.
  15. Sep 9, 2012 at 9:52 PM
    #95
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Did you chalk test this pressure? Seems awful high and I would be surprised if your chalk line wasn't worn more in the middle at this pressure.
  16. Oct 27, 2012 at 5:39 PM
    #96
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I have the same tires (10 ply). They told me 40 lbs front and back in my 06 dbl cab sport. Weird.
    I've been running them at 40 and no complaints.
  17. Nov 11, 2012 at 10:36 PM
    #97
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    I have the stock "Dunflops" on my 09 Double Cab. I was running 30 psi all around (like the door panel says) and I began to notice the front tires were wearing fairly quick on the outer edges. I am giving 35 all around a try. It hasnt been long but so far, so good. I may take the rear tires down a lb. or 2 for better traction.
  18. Dec 29, 2012 at 2:43 PM
    #98
    Bill Hill
    Bill Hill WILLIAM HILL
    William
    Mesquite, Texas 75149
    PreRunner
    20" Wheels GOODYEAR 285/50R20 TIRES BED COVER BACK UP CAMERA KENWOOD-DDX512
    OUT STANDING INFORMATION.
    THANKS
  19. Jan 19, 2013 at 2:57 PM
    #99
    Toyanvil
    Toyanvil Well-Known Member
    Did the chalk test today on my 08 DCLB sport 4x4 with 265/70/17C BFGoodrich T/A KOs, I use Nitrogen. Started with hot tires at 50 psi all around max for these tires and let out 2 psi at a time until the chalk was worn even. Final psi was 38 psi front 34 psi rear HOT, I checked it cold and it is 36 psi front and 32 psi rear Cold, this is Nitrogen.
  20. May 14, 2013 at 10:14 AM
    #100
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    How did u get 100k miles out of 1 set of tires?
    That would be a good thread ( how many miles do u get with your tires) to start
