What PSI
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HDFD10, Apr 8, 2010.
  1. Apr 8, 2010 at 3:56 PM
    HDFD10
    HDFD10 [OP] Well-Known Member
    Curious as to the PSI everyone is running their tires at for best MPG's. Mine currently are at 38lbs..
  2. Apr 8, 2010 at 4:17 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    With the BFG Rugged Trails I ran about 33PSI for daily driving and 35PSI for extended highway.
    It depends on the tire and what load rating they are, and what load (if any) you have in the truck normally.
  3. Apr 8, 2010 at 4:34 PM
    HDFD10
    They say you can inflate to somethin like 60psi cold. Not sure on the rating. They are 285/75/16 Big O Big foot AT's
  4. Apr 8, 2010 at 4:42 PM
    nvdeserted
    Reno, NV
    In that case you'll probably want to be in the 40-50psi range. 60PSI is for full size trucks under load. If they are an 'E load' tire they'll be stiffer and you might even want to run them in the 35psi range. Look around your tire: it should say 'D load' or 'E load' or if there is a 'P' before the tire size 'P285...' this will help us help you.
    If you really want to be accurate search/google 'tire chalk test', it's the best way to see what your ideal psi is for the weight of your truck.
    You can alway run them at a higher psi to save gas but you'll lose in the end when your tires wear out early.
  5. Apr 8, 2010 at 4:43 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i like 40 up front and 38 in the back.
  6. Apr 8, 2010 at 6:25 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    my sticker on my 09 dc lb says 29 front and 29 rear for 265/65/17
    that is what i use.
  7. Apr 8, 2010 at 7:23 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^It would differ with aftermarket tires, though.
    The best method is the chalk line method. Draw a chalk line width wise across the tire, drive a couple hundred feet, and see where it is worn off.
  8. Apr 9, 2010 at 1:41 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Always learn something on TW. Thanks [​IMG]
  9. Apr 9, 2010 at 1:48 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I run 40 PSI front and rear on my 285/70-17 Grizzly MTs
  10. Apr 9, 2010 at 1:52 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    29 PSI here
  11. Apr 9, 2010 at 3:15 AM
    joesilvertac08
    joesilvertac08 Well-Known Member
    Joey
    Newark, DE
    08 Toyota Tacoma DC SR5 4x4 TRDSports
    ARB front bumper, Safari Snorkel, Allpro kickout sliders, ArmorTech OffRoad Skid plates, TRD CAi, Toytec coilover front w/ 5100 Bilstein shocks, Bilstein 5100 rear shocks,Firestone airbags, Skyjacker AAL, 285/70R17 Cooper Discoverer STT LT, Magellan, Cobra 29LTD classic CB radio w/ 3' FireStick antenna.
    40 psi front and rear on my 285/75/17..
  12. Apr 9, 2010 at 8:14 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I run 35 front 30 rear. This seemed to be the best after I did the chalk line test on my 265-70-17 Duratracs. I have it set up alittle more firm than the chalk line told me so I can get slightly better mileage on trips.
  13. Apr 9, 2010 at 8:18 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    32 psi at all four wheels with stock tires. Even tire wear and good mileage at 17,000 miles. I rotate every 5000 miles.
  14. Apr 9, 2010 at 8:20 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    32 PSI front & back with 265/75/R16 tires. They all seem to be wearing evenly but I will still like to do the chalk line test if I could remember to do it.
  15. Apr 9, 2010 at 8:23 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I run about ~34 PSI all around on my 285/75/16 KM2s. My best tank was around 18.47 MPGs.
