what rating of a Jack and Jack Stand would I need for my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, Jul 15, 2011.
  1. Jul 15, 2011 at 8:14 AM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    I need to buy a jack and a jack stand and wondering what load strength should I buy? I have a 3 ton jack stand at home and wondering if that will work.
  2. Jul 15, 2011 at 9:42 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Just make sure it has enough lift if your truck is lifted. Or you wil have to use wood blocks also.
  3. Jul 15, 2011 at 9:47 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    i would buy a 3 ton floor jack and 6 ton stands I have a set of 2,4,6 & 12 tons and the 6 tons are the perfect size for a Tacoma the 4 tons are a little small. And my 2 tons are for my girls car And the 12 tons well are huge!
    Harbor Freight has a 3 ton jack on sale for 70 bucks right now with a coupon i just picked one up it's beefy as hell and the 6 Ton jack stands are 39.00 with a coupon.
  4. Jul 15, 2011 at 11:06 AM
    JUJtacoma2010
    Fresno
    thanks. I will stop by a store and get one
  5. Jul 15, 2011 at 11:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Check out Sears, I picked up a 3 Ton jack, 2 jack stands and a creeper in a kit for $100 this past Christmas!
  6. Jul 15, 2011 at 11:53 AM
    Pugga
    Massachusetts
    Damn, that sucks... I haven't had any issues with their stuff so far, knock on wood!
  7. Jul 15, 2011 at 12:41 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I've got two craftsman jack stands and a craftsman floor jack, absolutely no issues man.
  8. Jul 15, 2011 at 12:45 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you can find out the curb weight of your truck through toyota's website or google, then you look for the jack that is rated for at least that rate
  9. Jul 15, 2011 at 12:51 PM
    scocar
    scocar hypotenoper
    OP, you should be fine with a pari of 3 tons for stuff like axles and 6 tons for the frame rails, mainly need for height to keep the wheels off the ground, not weight capacity. But I like the added safety, too, when I am under there.
    I had a Crafstman jack that sucked, mainly because the release control was terrible.
    I got a 3.5 ton Arcon from Costo a couple years ago, and it is great. good height, quick lift, smooth, slow release. I know a few other guys here have them too and like it a lot. Like $89 at Costco 9when they have them, they do in Sac now) and about $130 at Northern Tool.
  10. Jul 15, 2011 at 1:18 PM
    Pugga
    Massachusetts
    I agree with you there, the release control is horrible on the Craftsman jack I have. I'm getting better with it but it lets go very quickly!
  11. Sep 23, 2012 at 3:19 PM
    Johnnyh
    Johnnyh Well-Known Member
    Az
    The basics, 5100s, 885s, weathertechs, Desert racing UCAs, wheelers progressive 3 leaf, icon rears, welded in magnaflow, ultragauge, drop in filter, bet mat, 285/75/16s
    I get that this thread is a year old, but just for future reference I've had one of those harbor freight jack stands fail on me. And had it not been for the jack doubling as a second safety I probably would have been in bad shape. The lip bent over that should lock it in place. Just food for thought, maybe I got a lemon
  12. Sep 23, 2012 at 3:30 PM
    Larry
    Larry CARL
    CARL
    I wouldn't buy a #2 pencil from harbor freight.
    Wallbright likes this.
  13. Sep 23, 2012 at 3:41 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I got the same deal a couple years ago...still working fine.
  14. Sep 23, 2012 at 3:55 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    or tape :D
  15. Sep 23, 2012 at 4:42 PM
    OffroadToy
    I thought i'd be safe buying zip ties there...NOT!!. The things are fucking garbage. :(
  16. Sep 23, 2012 at 5:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    LOL!
    Yup.
    Bought 1000 of them. Ended up packing up my worksite and driving 10 miles to an electronic wholesale shop.
    Things would seem to snug up, then they'd pop free like they had no teeth.
  17. Sep 23, 2012 at 6:01 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Try Harbor Freight.
    2 ton should be plenty.
    Just remember if you are just lifting one side of the vehicle you are only lifting about half the trucks weight or so.
    2 - 2 ton jacks = 8000 lbs
  18. Sep 23, 2012 at 9:44 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    when i was in high school, my welding teacher had weekly "safety lessons" that consisted of horrible pictures he would find on the internet. one of them was of a guy working on his car when his harbor freight jackstand failed on him. i will never buy one.
    i do however use a harbor freight floor jack as it was priced well, especially considering that it fits under my car. but i would never rely on it to hold something up. it pumps my truck up to whatever hight i need to get my jackstands under it and that is all.
  19. Sep 23, 2012 at 11:23 PM
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    I would go with 4 ton rated for both.
    Also, NEVER get under a vehicle with just a jack. I use jack stands and the jack for a back up.
    Oh, and never get under the front of a standard vehicle on a slight incline with your wife sitting in the drivers seat where she can push in the clutch (learned this the hard way).
  20. Sep 24, 2012 at 2:32 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Guys...you will only lift one corner of the vehicle at a time...so a 1.5 ton aluminium racing jack is all you really need.
    Get the better cast iron jack stands, with the easily adjustible height, and I think 3 ton is the standard size of those.
    A 3 ton floor jack is a BIG piece of equipment...
    Howard
