What rating of tire should I be looking for?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wolftaco0503, Jan 15, 2019.
What rating?
  1. E
    33.3%
  2. P
    66.7%
  3. D: all of the above
    0 vote(s)
    0.0%
  1. Jan 15, 2019 at 10:01 AM
    Wolftaco0503
    Wolftaco0503 [OP] Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    I know I going with Cooper Tire beyond that haven't narrow down the choices.
  2. Jan 15, 2019 at 11:55 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you off-road, carry heavy loads, and/or tow, you want to consider E rated tires. Keep in mind they average 50lbs each and will effect mileage.
    Norton likes this.
  3. Jan 15, 2019 at 12:36 PM
    Wolftaco0503
    Adam
    Chicago
    I don't tow or off road much but I'd like in the coming year. That is why I got my Taco after all. So what would be a good rating for a part-time off Roader?
  4. Jan 15, 2019 at 12:43 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    C load! Best ride. Only go up if your towing heavy loads.
    Sig45 likes this.
  5. Jan 15, 2019 at 12:50 PM
    Chuy
    Lakeside, CA
    Silver Taco
    E-rated tires are safer to air down, although I have air down on C-rated tires before with no issues. C-rated may be your ticket if you will only be doing light off-roading.
  6. Jan 15, 2019 at 12:51 PM
    eon_blue
    Azusa, CA
    Do not do a P rated tire if you're going to be doing any off roading
    C rated is fine if you mostly just want to hit fire roads and 2WD trails
    E rated if you want to get into the harder 4x4 stuff.
    Generally speaking
    Norton likes this.
  7. Jan 15, 2019 at 1:26 PM
    JayRolla
    Colorado Springs
    P rated should not even be considered. D ride rough and E are like riding on bricks.
    C load work fine offroad and are like fluffy clouds compared to Es. Only go with D if the tire you want is not offered in a C.
    Mully likes this.
  8. Jan 15, 2019 at 1:46 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    P-rated tires are more for on road comfort and performance. Go with a LT tire in a C or D load rating but you may not have a choice depending on the tire size or manufacturer. D load rating are too stiff for a Tacoma, more appropriate for full size trucks.
    Norton likes this.
  9. Jan 15, 2019 at 1:49 PM
    DirtTaco
    DirtTaco Well-Known Member
    I have E rated duratrax and although I really like the tire- it’s a bit of a rough ride. ( you really feel every crack and bump in the road.) also took a huge fuel economy loss.
  10. Jan 15, 2019 at 1:50 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    What rating is this?
  11. Jan 15, 2019 at 1:52 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    P Metric all the way
  12. Jan 15, 2019 at 2:46 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    On a lightweight Tacoma a "P" rated tire is all that is really needed, and unless you want an aggressive tire only sold in an LT tire I'd save my money and buy "P"'s. But other than cost there are very few downsides to going to an "E" rated tire. They are tougher, especially in the sidewalls and that might make a difference off road. The ride CAN be rougher, but "E" rated tires need less air pressure to give the same performance. I used to run 38-40 PSI in my "P" rated tires. On the ride home after having "E" tires installed the ride was stiff. I checked air pressure when I got home and it was at 50 PSI. After experimenting I settled on 35 PSI and the ride is no different than the older "P" tires.
    I wouldn't advise "C" rated tires. While they have an LT stamped on them their payload is LESS than the "P"'s that came from the factory. They are intended for lightweight SUV's like Wranglers that don't carry any loads at all. If going to an LT in a Tacoma buy a "D" or "E" rated tire. The "D" rated tires have the same payload as "P" rated tires.
    I've been buying tires since the 1970's. I've had all of them and never once noted any difference in fuel mileage when going to a HEAVIER tire. The "E" rated tires currently on my Tacoma give me exactly the same fuel mileage that I got before. I have noted a decrease in fuel mileage and ride quality in the past when going to a more aggressive tread. If you stay away from the aggressive mud tires and get an AT tire in an "E" rating the ride will be fine and you'll not lose any fuel mileage. Put some aggressive tractor type tires on there and it'll ride rough and burn more gas.
  13. Jan 15, 2019 at 3:09 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Flintstones
    Mully[QUOTED] likes this.
  14. Jan 15, 2019 at 4:07 PM
    MITCH36
    MITCH36 Member
    evergreen, co.
    07 Tacoma 4x4 DCLB- SPEEDWAY BLUE & 07 T4R Sport v8 BRIGHT WHITE
    Snug top topper, OEM roof racks, Bilstein 4600 shocks.
    I had P rated Dynapros on mine and they were good all around. They were replaced with E rated LT 265 70-17 Wildpeak AT3Ws, (got a good deal on them),my mileage dropped about1-2 mpg, didn't notice any change in ride quality and I'm really happy with them. We do a fair amount of off roading and towing so the E's work for me. Mitch.
  15. Jan 15, 2019 at 4:30 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    I'm 'stumped' on the load rating. That size 'wood' require a 'chop' to the cab mount. I wood 'ax' that tire brand and search for a more comfortable tire that you can 'log' a lot of miles on along with added fuel 'shavings'.
    Messina05, Mully[QUOTED] and Armkb like this.
  16. Jan 15, 2019 at 4:33 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  17. Jan 15, 2019 at 4:48 PM
    Mully
    CA
    Wood, chop, ax, log, shavings. Well said my friend, well said.
  18. Jan 15, 2019 at 5:45 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Falken c rate
