what rating offroad tires is eveyone running ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jp59inh, May 15, 2018.
  1. May 15, 2018 at 10:18 PM
    jp59inh
    jp59inh [OP] Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    I am wondering if running an E rated tire compared to a C rated tire is going to make a huge difference on power due to the weight differences ?
    What have you guys noticed ?
    Thanks
  2. May 15, 2018 at 10:29 PM
    US Marine
    US Marine Semper Fi
    Chuck
    High Desert - Hesperia Ca
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'm running 265/70 16 Toyo Open Country Mud Terrains load range E . I notice no driveability issues
  3. May 16, 2018 at 6:11 AM
    BajaSurfRig
    BajaSurfRig Well-Known Member
    2000 Tacoma 4wd Trd 5sp Callen Camper
    I am running 235/85 r16's KO2's in LR E. They are heavier and stiffer but I have yet to get a flat on hundreds of miles of Baja dirt roads with these tires (unlike by General Grabber AT2's 31x105.x15 LR C that had two side wall failures on back to back trips...). If you are doing a ton of dirt roads it is worth it. If not probably stick with what you are running.
  4. May 16, 2018 at 6:16 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA / Greenville
    1st gen 3rz 5spd+18'inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    If only I would have saved it but some website did a test of two 35" tires on the same wheels with the same vehicle. E load tire at almost 80lbs and c load at around 48lbs.
    Acceleration was a .2 second difference. Mpg was a .3 difference. Only thing worth noting was stopping, dont remember exactly but it was over 50ft extra.
    I searched for years on the lightest tires, I used to be able to tell what every 33" tire weighed. When I saw that post, gave up and now run e load 33s at around 65lbs a piece
  5. May 16, 2018 at 6:28 AM
    Tocamo
    Tocamo Not to be confused with Camel Toe
    Rick
    Ottawa, Ontario. Capital of Canada
    2017 OFF-ROAD DCSB Quicksand
    Wow, if that's what's happening with the Brakes, imagine the rest of the suspension....:ballchain:
    Danno1985 likes this.
  6. May 16, 2018 at 6:38 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I ran e for years no problem.
    Went back to c and realized the e rode like bricks. Cs soak up a lot more of the road.
    Prayn4surf likes this.
  7. May 16, 2018 at 6:52 AM
    Clearwater Bill
    Clearwater Bill Retire from work, but not from life.
    Billy
    Clearwater Florida
    '13 5 lug base AC w/convenience package
    The benefit to move to an E is if you are constantly in harsh terrain where damage is a high risk.
    jp59inh [OP] likes this.
  8. May 16, 2018 at 6:53 AM
    MO Tacoma
    MO Tacoma Well-Known Member
    Missouri
    2014 Double Cab Long Bed mid travel
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    Currently I'm running 35×12.50r17 Toyo OC AT2 xtreme E load. The lungs are further apart with the xtreme version. Unsprung weight you will feel but rolling resistance is something a lot of people overlook. It's an aggressive AT tire but it's not a crazy rolling resistance either. If I had the same weight and size tire but crazy aggressive tread pattern, I would feel it even more. With all that being said, if you're running the same size tire but changing it to e load I wouldn't think it would make that big of a difference. If you add a crazy aggressive tire and e load then you'll feel it a little more. It will affect a 4 banger more than a v6. I'm not trying to make it more complicated but there are a lot of elements that go into it. Your tolerance level has a lot to do with it too. I've know people to run 35s with stock gears and say it's not that bad. Then you have someone standing right next to him complaining about power loss moving up to 285s with stock gears. Just going off of everyone's advice the guy with 20 lbs more per tire running 35s should be the one complaining but that wasn't that situation. An easy way to look at it is many people have done way more than what you're talking about and still consider it very tolerable but each element you change(unsprung weight, tire height, rolling resistance) will affect power to some degree. You just add one element and it won't be too different from what you're used to but when you start combining multiple elements together and the effects will be more. Hope the info helps.
  9. May 16, 2018 at 7:42 AM
    JayRolla
    Colorado Springs
    Really it's best for towing. Never lost a tire on a trail in 15 years down airing to 12psi.
    Knock on wood.
  10. May 16, 2018 at 8:36 AM
    Clearwater Bill
    Billy
    Clearwater Florida
    Yes, that too. Since I never tow heavy anymore I do forget that.
    JayRolla likes this.
  11. May 16, 2018 at 8:46 AM
    rnish
    rnish Well-Known Member
    Maryland USA
    Tacoma
    115 load Cooper ATW's. Good in the snow and as good as can be expected ice traction. Does well on the beach/sand. I do fire trails, light towing nothing requiring an E rated tire. Quiet on the highway.
  12. May 16, 2018 at 9:22 AM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Currently on E load All Terrains (KO's).
    Are they heavier? Sure. But so are bigger tires in general.
    Do they suck all the power out of your truck? No.
    Have I ever gotten a flat? No.
    Street? Go C load.
    Off road? Get E load.
    D range would probably be a decent compromise, there is definitely a much more limited selection of sizes and tread designs.
  13. May 16, 2018 at 9:24 AM
    eon_blue
    eon_blue got boost?
    Monrovia, CA
    2004 3.4l TRD 4x4 Tacoma XtraCab w/5 speed
    E rated BFG KO2s....been wheeling almost every weekend for nearly 2 years on them (2nd set now). Never once had a puncture, blowout, flat or tire issue of any kind. I'll never go with anything but an E rated tire for a wheeling rig.
    That said, they can be brutal on the street. You feel every bump in the road and they are heavy (bad MPGs). So there's a definite trade-off for the offroad peace of mind.
    jp59inh [OP] and JayRolla like this.
  14. May 16, 2018 at 9:42 AM
    jbrandt
    Sacramento, CA
    I've never owned anything different than the E rated that are on my Tacoma now (I bought it with them - on my 2nd set). So I've never known anything different.
    I've always attributed the "better" street ride from my '17 4Runner to the fact that it's almost 15 years newer, quieter, and has lame softy street shocks (it's the DD, and wife wants the soft ride for road trips etc...). The little street slicks it came with I'm sure contributes to that ride, though...
    eon_blue likes this.
  15. May 16, 2018 at 10:31 AM
    eon_blue
    eon_blue got boost?
    Monrovia, CA
    Yeah for a while I wondered why my ride was still so rough even with the new suspension (Kings/Icons) and I realized it's the tires. Airing down helps a ton offroad but they are still way stiffer than a more street friendly tire. Especially on a relatively light truck. Just one of those trade offs.
    I do think KO2s are a bit more notorious for it than most because of their stiff yet nearly indestructible sidewalls...other E rated tires might not be as rough on the street.
  16. May 16, 2018 at 12:15 PM
    jp59inh
    None yet
    I run Toyo AT2 extemes on my F150 , they are E rated and I run them at 34 psi on the street so they arent hard as rock . They also wear evenly at this psi.
    I was just concerned about running an E on my lil taco being that its even lighter than my other truck.
  17. May 16, 2018 at 12:32 PM
    US Marine
    US Marine Semper Fi
    Chuck
    With my Toyo Open Country tires that I previously mentioned I used the chalk line test to get the tire press correct
    Found that 28psi I got even tread wear even with a load range E tire
  18. May 16, 2018 at 12:39 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Brock
    Louisiana
    2001 Green Double Cab 4x4
    Bilstein 5100's w/ Toytec AAL & BFG KO2's
    I ran C-rated tires for years and seemed to always have a puncture or 2 in every set I ran. Since swapping to E rated BFG “KM2’s, KO’s and now KO2’s” I haven’t had a puncture in the last 8 years. Sure the E’s ride rough, but it’s a truck and I hate flats.
    Edit: I also run mine at 32psi
    US Marine likes this.
  19. May 16, 2018 at 12:50 PM
    jbrandt
    Sacramento, CA
    This is a good thing to point out: that just because the E rated tires have a max of 80psi, you don't need to run them that high (that's just if you're towing really heavy loads (like out Tacos could handle that much weight anyway, lol). There's no need to Flintstone it and run "hard as rock" pressures.
    I've been running ~32 psi on the street the last decade+ with KOs, and they wear very evenly at this pressure.
  20. May 16, 2018 at 1:10 PM
    eon_blue
    eon_blue got boost?
    Monrovia, CA
    my god I couldn't even imagine what running KO2s at 80 psi would feel like...one tiny rock in the road would probably make you lose control of your truck
    US Marine and 01GreenTacoma like this.
