What rating would you give for reliability?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JP2, Nov 3, 2017.
How reliable is my Tacoma 4x4?
Poll closed Nov 17, 2017.
  1. 1
    2.6%
  2. 2
    0 vote(s)
    0.0%
  3. 3
    0 vote(s)
    0.0%
  4. 4
    2.6%
  5. 5
    20.5%
  6. 6
    2.6%
  7. 7
    2.6%
  8. 8
    5.1%
  9. 9
    33.3%
  10. 10
    30.8%
  11. Decent enough.
    0 vote(s)
    0.0%
  1. Nov 3, 2017 at 8:03 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    My truck ticks, not sure if it's an exhaust leak or not but it has been doing it for around 16k miles. That hasn't done anything to effect anything as of yet, now cv axle wise i have grease everywhere and my steering has gotten stiffer from mud entering the joints.
    As of everything, the mf'ing clamp that holds the exhaust right before the afr sensor will not stay in it's place, I've tightened it down twice and now it is rattling again. Also, not hindering the truck as of yet
    Replaced both o2 and afr sensor when I first got it. At 160k I was okay with that, it's a mechanical part.
    Just be glad you don't own a chevy
  2. Nov 3, 2017 at 8:03 PM
    eon_blue
    Azusa, CA
    I've had my fair share of headaches with my truck over the past year and a half that I've owned it....bought it with 24k miles on it and currently at 57k.
    1st real issue was a PO171 check engine light. Fortunately, it was still under the 30 day dealership warranty but they couldn't figure it out right away. Replaced spark plugs, wires, MAF, O2 and air/fuel sensors and finally figured out that it was a vacuum leak on the supercharger.
    Lower ball joints started leaking so got those replaced.
    New clutch put in because the throwout bearing on the OEM one was chirping like mad (new one is now, too).
    Truck was running really lean because of the supercharger so I got the URD 7th injector kit installed (including new fuel pump and spark plugs)
    Replaced the aftermarket e-fans with a fan clutch because the e-fans caused the truck to overheat.
    Had to replace the catalytic converters due to a P0420 code.
    ....and probably a few other things I'm forgetting, lol.
    But most of these things are due to the aftermarket components that the previous owner put on, and the rest are from the beating that my truck takes offroading every other weekend.
    She's never once left me stranded anywhere so I'll give her that. I'd say 8/10 for mine.
    Dalandser likes this.
  3. Nov 3, 2017 at 8:07 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    I'm not saying it should last 300k+, but longer than suspension, for sure.
    Also, def not an exhaust leak. I've checked. It's the top end of the engine. Just not sure where...
    Don't get me started on chevys. Best part of owning a Chevy is selling it:bananadance:
    Edit: I have also replaced both AFR and O2 sensors due to an engine code. Other than that, all the maintenance that wasn't done by PO. Fluids, plugs, brakes, suspension, timing belt, you know the drill.
  4. Nov 3, 2017 at 8:14 PM
    GreeGunc
    Jacob
    North GA
    You're a 5vz?
    I'm wondering what mine needs, I know my throw out bearing is chirping also. Like bad, but I'm either stuffing in an ls1 or turboing the 3rz, either way I'll have to tear everything out to do one or the other
    And I can't talk to much on Chevy, my dad has 2.....old school but still
  5. Nov 3, 2017 at 8:17 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Yep, 5vzfe. I would only consider a Toyota v8 swap or a diesel. But chances are another 3.4. Truck needs to last a lifetime, so swap is inevitable once this motor goes.
    But why rush things, she only has 130k on the clock:eek:
  6. Nov 3, 2017 at 8:18 PM
    eon_blue
    Azusa, CA
    The throwout bearing chirp is just something I've learned to live with. It comes and goes, not worth replacing my clutch again with only 25k miles on it. Its incredibly unlikely that the TOB will actually fail (bad news if it does though).
  7. Nov 3, 2017 at 8:19 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    woops... i did same
  8. Nov 3, 2017 at 8:26 PM
    GreeGunc
    Jacob
    North GA
    I would like to keep it toyota, but i couldn't find an adapter plate for a stick shift behind the 1 uz and diesel is to heavy for what I plan to use mine. 1-2jz was finding a place for the intercooler with a plate bumper and winch.
    Besides, full aluminum engine pushing out 305hp based off the well known 350 small block, parts are plentiful
  9. Nov 3, 2017 at 8:30 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    True. Dealers tend to just throw parts at vehicles. You shouldn’t be going through 3 MAFs like that. Seems like something is causing the MAFs to go bad, or something else is causing the cylinder(s) to misfire.
    Currygoat and Dalandser like this.
  10. Nov 3, 2017 at 8:49 PM
    TeeYoda
    TeeYoda Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
    My '03 2.7L just rolled past 270,000 miles. She's been the most reliable vehicle I've owned. I replaced the steering rack at 200,000 miles due to leaking & have had to replace a rear axle seal a few times because of leaks. The engine & transmission have had zeros issues.
  11. Nov 4, 2017 at 7:46 AM
    Crock112
    Crock112 Well-Known Member
    Crock
    New England
    '04 2.7l SR5 4x4 xtracab
    I've put almost 70k miles on my '04 2.7l 4x4 in the 4 years I've owned it- 64k miles to 132k, and only done brakes and oil changes. By far the most reliable vehicle I've owned- she's not perfect and is due for a little preventive maintenance but starts every time, no matter how cold, and has easily handled everything I've put it through. Hoping as long as I treat her right, I can give it to my son in 16 years and he can have some adventures.
  12. Nov 4, 2017 at 1:22 PM
    jbrandt
    Justin
    My son is going to have to buy his own... I’m keeping mine for, like, ever.
    “From my cold dead hands” rings a bell here... ;)
    arctic04trd likes this.
  13. Nov 4, 2017 at 1:36 PM
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    I drive a 2016 now, gave my 2001 to my son after 15 years. Gave it a 9, not a 10 because my blinker fluid is always low. Aside from replacing the norm, timing belt, some sensors, etc... The truck has been awesome, still is for my son. Only gave it up because my son needed something better to drive at age 18, because what we got him at age 16 was crap, or I would still be driving it.
    The truck is completely stock, my 2016 is already getting mods:), used it for everything, camping/hockey trips/off road/etc... and never owned anything better in the snow! No regrets buying it!!! 220k miles later!!
  14. Nov 4, 2017 at 1:57 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Normal maintenance
    Oil change (5K DINO)
    Front brakes (3rd set)
    2 trans fluid changes
    2 battery
    2 Trans changes
    2 air filters
    2 radiator fluid
    Replaced at 185K miles- non routine:
    I have also replaced ignition cylinder OEM.
    I have replaced brake Master cylinder.
    New radiator
    New headlights
    Upcoming things I need to do:
    1) Needs 02 sensors now. ($180)
    2) Needs rear drum pads (first time in 200K miles)
    3) Needs CATs replaced ($650)
    4)My passenger door rear lock will eventually need replacing.
    Its driven on a farm, 8 months of the year. City 4 months of the year. Bed has 600-700lbs of dates in it.
    A/C works
    No oil burn
    No leaks.
    Stock trans. Stock motor. Stock suspension. Nothing else every touched. No accidents, no paintwork.
    LOVE MY TRUCK - best American built automobile ever.
    Currygoat and SouthernYoder like this.
  15. Nov 4, 2017 at 7:53 PM
    #35
    jbrandt
    Justin
    @PROseur,
    Yeah, I like that I can drive to where my truck was built (numi plant). I always liked to tease the domestic guys because their truck was probably built in mexico or canada.
    Currygoat likes this.
  16. Nov 4, 2017 at 8:01 PM
    #36
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Nothing wrong with Canada :rolleyes:
    :canada:
  17. Nov 4, 2017 at 9:28 PM
    #37
    1997tacomav6
    Denver
    Yep, mine was built in California and original owner I am and supercharger I had installed in 1998, so the supercharger has about 520,000 miles on it, rebuilt 3 times and truck has 545,000 miles. I give my truck a 9 just because at 480,000
    the head gaskets went out which is typically
  18. Nov 4, 2017 at 10:24 PM
    #38
    jbrandt
    Justin
    There is when you owner of a vehicle is trying to brag about his big “american” truck...
  19. Nov 4, 2017 at 10:26 PM
    #39
    jbrandt
    Justin
    Just gettin broken in!
    1997tacomav6[QUOTED] likes this.
  20. Nov 5, 2017 at 1:04 AM
    #40
    PROseur
    Pussy
    Gen 1
    Hands down best American automobile
    Love the reliability
    I used to live right down the street from nummi
