What rear diff locker should i go with
Discussion in '1st Gen. Tacomas (1995-2004)' started by 06toyoboy, Oct 8, 2011.
  1. Oct 8, 2011 at 7:52 AM
    06toyoboy
    06toyoboy [OP] Well-Known Member
    Im a newb at this, but was wondering what rear locker i should go with?
  2. Oct 8, 2011 at 7:53 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    do you want it to be selectable or locked all the time?
  3. Oct 8, 2011 at 7:59 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    And what is your budget? Give us a little more info here....
  4. Oct 8, 2011 at 8:02 AM
    06toyoboy
    i would like to be selectable and i would have a budget of about $500. i dont know how much they go for exactly
  5. Oct 8, 2011 at 8:10 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Powetrax no slip
  6. Oct 8, 2011 at 8:17 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Is this for the part and installation? Will you be doing it yourself? Do you drive in snow or ice? Labor is going to eat up a bit and possibly more if you want a selectable which may require an OBA (On board air) on top of a locker.
    Looks like your budget will only allow a lunchbox type locker which replaces the spider gears, those lockers are inexpensive and easy to install and should come in under budget, but I dont like them on the street because they degrade the on road performance characteristics, you get what you pay for.
  7. Oct 8, 2011 at 8:26 AM
    06toyoboy
    500 would only be for buying it. i have no skills when it comes to working on my truck yet, but i know i would have to pay for the install wich i wouldnt mind. And one more queestion for the SoCal guys do any of you know good shops to go and get this thing installed.
  8. Oct 8, 2011 at 8:28 AM
    Speed Freek
    So cal is a big place, I am in Vista and I can do it while you wait...I can also help you with the proper locker / LSD selection depending on what your doing with it..PM me if you would like, I have a full shop at my home..
  9. Oct 8, 2011 at 10:06 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Do you have a shop or is it a home garage? Thanks!
  10. Oct 8, 2011 at 10:20 AM
    Speed Freek
    I work from my garage, but I have tons of tools, compressor, benders, welders, and I work on about everythig under the sun, I dont want to open a shop since all the fees attached casue you to overcharge customers...
    If you need anything let me know, I can help you out and save you some money and most of all DO it right!
  11. Oct 8, 2011 at 10:35 AM
    David K
    Thank you! I live just north of Vista near the mission... I will PM you about prices for things my 2010 Tacoma will need soon (front brakes if you do that incl. re-surface rotors, differential fluid change, etc.). I work in Vista a lot of the time (self employed installer/ repairs of drip irrigation & sprinkler systems).
  12. Oct 8, 2011 at 12:21 PM
    06toyoboy
    Yes socal is big bit vista is a long drive. I stay in Riverside
  13. Oct 8, 2011 at 11:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sounds like a TRD E locker will be good for you. ARB is 800-1000 for just the diff and another 250 for the OBA system
  14. Oct 9, 2011 at 10:25 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Ya try and find a trd truck at the junk yard and salvage the e-locker from it.
  15. Oct 9, 2011 at 10:59 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Trd full axle elocker on TTORA $500 in SLC.
  16. Nov 10, 2011 at 4:25 PM
    06toyoboy
    dont meen to bring this up again, but i am going with arb for the locker. my question is what size will it be. is it an 8.5? and also will i need a compressor?
  17. Nov 10, 2011 at 4:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  18. Nov 10, 2011 at 4:48 PM
    06toyoboy
    cool thanks just making sure
  19. Nov 10, 2011 at 7:35 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Apologizes to the OP, for thread jacking but is there any advantages over replacing my stock selectable locker with an after market brand? thanks
  20. Nov 10, 2011 at 8:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes actually. But only if you wheel really hard. If you just wheel kinda light, your E locker will be more then enough.
