What Rear Differential and Manual Transmission Oil Do I Need?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyboy718, Apr 26, 2017.
  1. Apr 28, 2017 at 1:48 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    butt I don't have sex with my truck, only in my truck
  2. Apr 28, 2017 at 1:53 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    @flyboy718 I change them at 30k. Sometimes less if I know I'm going to be busy. Sometimes a little more like now. I'm a little over 40k right now and the shifting is getting notchy. It smooths right out with the fluid change. At 30k I don't really notice the shifting until I put new fluid in and it's so much nicer.
  3. Apr 28, 2017 at 2:04 PM
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    :thumbsup::thumbsup:
  4. Apr 28, 2017 at 2:09 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    you should be fine with the 80w90_ I got a 2004 Tundra that ran on 75w-90 for over 200k miles worth of towing heavy loads; a car trailer and lots of cars going anywhere from 100-2000miles each time for over 8 years before my dad ended up totaling the truck; slid on ice and slam into a guard rail. No problems whatsoever; just keep maintenance on the fluid; change it out every 50-60k miles and you should be fine; in fact you can probably go longer, just check the fluid condition every 30k miles. Remove fill plug and check; if its dark change it.
    In fact my brother in law's mom owns a 1992 Toyota Previa that has never changed geared fluid at all for 400k miles; it was awful when we went to replace it. Smell really bad and the gear fluid was a dark as dark can be; lots of metal shavings and such; inspected the gears and no major problems at all. Put new fluid in it and it drove much smoother; that van is still driving today, now nearing 600k miles and trouble free.
    Point is; you don't gotta worry that much about gear fluid; run what Toyota says to run or go with any fluid of choice because I bet they all will do their job. You just have to keep up on maintenance; change them when needed and your good to go. The only time I've ever seen differential problems is with low fluid or no fluid; or abuse.
    Greenbean and Hartford like this.
  5. Apr 28, 2017 at 2:27 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Another vote for Redline.
    Made a bigger difference to me over Valvoline on my 6SPD.
    Most manufacturers have web sites with application guides.
    Pick your poison and get their recommendation. Each is different because of additives.
    I'd do yourself a favor and read these before you make a choice. There are good reasons there are two.
    MT-75/90GL4 -Transmission
    75/90GL5 - Differentials
  6. Apr 28, 2017 at 6:07 PM
    TA 4
    TA 4 Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    I recently just replaced all the fluids in my truck at 50,000km. Like you I was wondering about the same thing regarding the trans fluid. After tons of research, Gl-5 is safe for our trucks, however even talking with the local service manager about the fluid, he said a "Gl-5 should....be safe", but if in doubt use a Gl-4. I ended up running Royal Purple 75w-90 synthetic, which states on the bottle that its a Gl4/5 and also states its safe/designed for use in transmissions and any soft yellow metals. Truck now shifts a little smoother than before. Im sure other oils would be fine, but good for reassurance to know the oil is safe for the tranny
    As for the diffs and transfer case, I ran Shell Spirax synthetic 75w-90 (states to be used for axles/driveline), shell makes other variants of their oils which are specifically meant for transmissions.
    Royal purple is 20$ a quart (CAD), similiar to redline and the shell oil is 13$/quart.
  7. Apr 29, 2017 at 5:12 AM
    fatrip
    fatrip Well-Known Member
    Vince
    Upstate NY
    07 Taco 4D Short
    Bilstein 5100's , 885.
    Don't mean to hi jack the thread, but what diff fluid are people using with an air locker? I have read a few things as to not wanting anything with a friction reducer in it.
  8. Apr 29, 2017 at 5:25 AM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
  9. Apr 29, 2017 at 5:50 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Any brand in the required viscosity range will function. Don't worry much about the GL4 vs GL5 business and synchros - Toyota has been specifying GL5 as an acceptable type for Taco manual tranmissions since 1996. However, shift feel is subjective. Redline MT-90 gotten positive reviews from more people. How much better it is vs a "mainstream" brand synthetic 75W90 will probably vary from person to person.
    Yep.
    Norton likes this.
  10. Apr 29, 2017 at 7:05 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 to ALL of this. FWIW, my "mainstream" brand is Amsoil. Their Severe Gear 75W-90 is the "one size fits all" gear oil for ALL our vehicles, which greatly simplifies what to buy/stock in the garage.
    Synthetic works as well (some would say better) than conventional oil in just about every application of which I can think.
  11. Apr 29, 2017 at 7:22 AM
    flyboy718
    flyboy718 [OP] Well-Known Member
    Dallas
    05 Prerunner 4 cyl manual 226,000 miles
    Headed to my local race shop to pick up the Redline MT-90 for the manual transmission but they don't carry the 75W-140 that I would like to use for my rear diff; they do have the 75W-90 for the rear diff though. I am going to run to my local O'Reilly's to pick up Royal Purple 75W-140 for my rear differential.
  12. Apr 29, 2017 at 1:49 PM
    flyboy718
    Dallas
    Well $h!t. something always freakin happens. I got three quarts of Redline. I go to Autozone to get the little handpump. I start pumping into my transmission and the freakin chinese crap pump leaks like freakin crazy. I must have lost a half a bottle! I still need more to top it off after pumping probably 2 1/2 bottles in and the other 1/2 bottle is on the ground! I have no place open right now to get Redline! Can I mix something else with this Redline or am I screwed?
  13. Apr 30, 2017 at 6:21 AM
    flyboy718
    Dallas
    Going to wait and get a bottle or two of Redline to top it off with tomorrow and just take the wife's Rav4 to work
  14. Apr 30, 2017 at 6:46 AM
    KenLyns
    Belly of the Beast
    Day 3: Rav4 is surprisingly nice. Gonna trade in my Taco! Goodbye TW!
    Day 4: What's the biggest tire you can fit on a Rav4 without trimming?
    :p
    Hartford likes this.
  15. Apr 30, 2017 at 1:44 PM
    #35
    flyboy718
    Dallas
    No way! I looked like a pansy getting out of it at the gym last night. I don't normally start my workouts at the benchpress but I I went straight to it and racked 225.
  16. Apr 30, 2017 at 2:03 PM
    #36
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Another for Red line MT90.
    Just replaced my trans fluid with it on my new to me 09 with 75k. Looks like the owner never changed any of the oil besides engine.
    I went ahead with new oil in the rear/front diff and transfer case. Drives great and I like the peace of mind.
    The Red line made shifting a tad more notchy. Precise is the word, and smooth..
  17. May 2, 2017 at 6:29 AM
    #37
    flyboy718
    Dallas
    Well, a happy ending. I got it topped off last night and it only took another half quart. I am loving the Redline!
    KenLyns and Hartford like this.
  18. May 3, 2017 at 12:24 AM
    #38
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    I'm looking at a $423.43 order from Red Line right now. This includes every fluid in the truck besides coolant and windshield wiper fluid. Got some WaterWetter for s**ts-and-giggles. Also some SI-1 Fuel System Cleaner and CV-2 Moly Grease. Going to flush my transmission (A/T), brake fluid and power steering fluid as well as change the oil in engine, diffs, and transfer case.
