What Rear Differential Fluid for 2011 DC 4X4 Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bolt79, Jan 18, 2013.
  1. Jan 18, 2013 at 2:09 PM
    Bolt79
    Bolt79 [OP] Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    Ok, I've searched the forum but I'm still not settled on what differential fluid I should go with on my first (30,000 mile) rear differential oil change. The guy at the dealership said that I did not need a limited-slip additive.
    Could I hear from some other 2011 4X4 Sport owners on what they use.
    Thanks.
  2. Jan 18, 2013 at 2:14 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    If on the street primarily I recommend 80-90, if you offroad a lot I would recommend using the 75-140 to reduce shock loads and for more protection to the gears at the cost of greater parasitics since the oil is thicker and therefore resists movement a bit more.
    Hope this helps.
  3. Jan 18, 2013 at 3:51 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    i used mobil 1 75-90 on my 09 sport
  4. Jan 20, 2013 at 4:17 PM
    Bolt79
    White Springs, FL
    Thanks guys...any issues using synthetic?
  5. Jan 20, 2013 at 4:30 PM
    Chris24
    Greensboro, NC
    haven't heard of any or had any
  6. Jan 21, 2013 at 1:02 PM
    Bolt79
    White Springs, FL
    Kinda leaning toward the Mobile 1 synthetic. Thanks for the responses.
  7. Jan 21, 2013 at 5:16 PM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Redline synthetic. End. Of. Story.
    Redline products are the only ones on the market to use 100% synthetic base stocks. Their stuff is known to be the best of the best, and many people even swear it's overkill even for hardcore racing.
    When I told the guy ringing me up what I was using it for (all three gearboxes on my 4x4 Taco), he told me he doesn't expect to see me again for another three years at the earliest -- he said it should last me a good 50,000 miles easily, and still give better protection than even Mobil1 changed out on schedule. Of course, having been a Redline user for many years, I already knew this.
    Btw- I used Redline in my last minitruck. Changed the oil once a year. Never changed the gearbox oils again. Dude who bought it from me had his mechanic look the truck over, and ask when the transmission had been replaced. The answer was never -- it looked new enough to fool a good mechanic. The gear oils had 125,000 miles on it......and I got the truck with 60,000 on the clock.
    I have no affiliation with Redline. I'm just a really happy, long-term user of their stuff.
  8. Jan 23, 2013 at 5:42 AM
    Bolt79
    White Springs, FL
    Well, changed the oil yesterday. Ending up using Valvoline 75w-90 synthetic.
    However, I think I may have a problem...the manual says the rear diff oil capacity is 3.12 qts. I ended putting around 3 and 1/2 qts. in mine before it started to run out of the fill hole. Now I'm worried that I've overfilled it and could blow out an axle seal.
    Should I drain out some of the oil?
  9. Jan 23, 2013 at 7:29 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Just use mobile 1, I have had in all my front, rear diff, transfer with no issues, 2011 trd 4x4 lockers all around @ 39k miles, never an issues.
