What rear differential oil to use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ta2010, Oct 27, 2017.
  1. Oct 27, 2017 at 1:27 PM
    ta2010
    ta2010 [OP] Member
    2010 black Tacoma 4dx2
    I have a question on my 2010 tacoma there is no LSD sticker on the rearend so what oil should i use full
    synthetic or regular differential oil and do i need to put in an additive? THANKS
    NAAC3TACO likes this.
  2. Oct 27, 2017 at 1:32 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    No additive required in 2010. Most TW members use 75w90 synthetic.
    Philrab, Key-Rei and tcBob like this.
  3. Oct 27, 2017 at 2:03 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    my dealership in Houston uses Valvoline 75w90 synthetic. I bought it on Amazon.
  4. Oct 27, 2017 at 2:18 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    just picked up a bunch of Redline 75w90. meets GL-5 requirements..has the friction modifier in it..which neither one of us needs.
    O'DubhGhaill and Key-Rei like this.
  5. Oct 27, 2017 at 2:57 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    What dealership is that?
  6. Oct 27, 2017 at 3:38 PM
    UBYBC
    2014 Tacoma TRD OR
    McGill Toyota in Houston
  7. Oct 27, 2017 at 3:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    OTC lube of the GL and wgt that your owners manual calls for. Mobil 1, Valvoline, etc. No boutique stuff needed.
    If you follow normal service cycles and don't tow heavy or abuse the diff, dino is just fine.
    If you are hard on the diff, syn could be helpful by staying 'healthier' during heat cycles.
    If you are not hard on the diff, and use syn, then double your change intervals.
    Key-Rei likes this.
  8. Oct 27, 2017 at 4:01 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I use the same stuff. I buy it at Pep Boys but they likely sell it at any auto parts store.
  9. Oct 27, 2017 at 9:06 PM
    ta2010
    ta2010 [OP] Member
    THANK YOU FOR YOUR HELP
    NAAC3TACO and Key-Rei like this.
  10. Oct 28, 2017 at 3:47 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Mobil 1 75W90 Synthetic
  11. Oct 28, 2017 at 4:35 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Whatever you decide to use, buy it at Walmart for best price.
    asuchemist likes this.
  12. Oct 28, 2017 at 4:46 AM
    jacoblb
    jacoblb Well-Known Member
    MD
    2010 AC 2.7L
    FWIW I used Lucas 85w140 in the diffs. I'd seen on here it was the recommended oil by ECGS who pretty much do diffs for a living. Redline MT-90 in the Xmsn and xfercase
    tacoman45 and mrbetelman like this.
  13. Oct 28, 2017 at 4:52 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    75w90 Toyota brand bought to change in my 2012. I've used Lucas in my 2003 before selling it. Both had the electric locker in the rear. Never added anything special, owners manual doesn't call for it.:thumbsup:
  14. Oct 28, 2017 at 7:21 AM
    TexasWhiteIce
    Texas
    I was reading synthetic gear oil isn’t good for our differentials. Is that true?
    Partychief67 likes this.
  15. Oct 28, 2017 at 8:12 AM
    Pigpen
    Dan
    Northwest Montana
    This is what I just put in my rear diff, for the same reason mentioned in the quote. I had some M1 syn laying around, so that's what went in the front. I've been using the Mobil 1 for the truck's whole life so far - 95K miles.
    Sna and jacoblb[QUOTED] like this.
  16. Oct 28, 2017 at 3:53 PM
    UBYBC
    2014 Tacoma TRD OR
    After two years of watching people here use synthetic with zero issues I’d say it’s fine. The sport model needs an LSD additive I think. Either way, can you cite what your reading that says it’s bad.
  17. Oct 30, 2017 at 5:16 AM
    rothy3652
    rothy3652 Member
    2017 DCLB sport
    My truck is a 2015 sport. I am at 37,000 miles and currently going through the 30k service items. I am leaning towards doing the driveline as well even though it’s not on the schedule till 60k. I do tow a small trailer a few times through the year so I figured it wouldn’t hurt swapping the rear differential fluid. The transfer and front diff are rarely loaded but since I’m set up for it I might as well go for it. I have chosen 75-90 valvoline non synthetic for all three components. The 75w85 at Toyota was quoted by the dealer at 36 a liter. Is this a synthetic? Should I stay synthetic if it is? Not interested in brand preference just curious on what is in my truck. This truck is highway use and again occasional trailer use with a light load.
    vwarwar likes this.
  18. Oct 30, 2017 at 5:33 AM
    jacoblb
    MD
    2010 AC 2.7L
    The Toyota is not synthetic. Changing it now may be a little preemptive. Unless you were to change them to synthetic and baseline your oils, imo it isn't necessary to change them. Especially according to your use description.
    Edit: Yeah you have Dino oil in it now if it's never been changed.
  19. Oct 30, 2017 at 6:20 AM
    rothy3652
    rothy3652 Member
    2017 DCLB sport
    Thanks for your opinion. I was leaning on just doing the rear diff but then got to thinking while I had a mess going to just do it all. The fluids are original and the truck has an easy life so I may just hold off till 50 or around there. On another thought why would anyone pay a premium for a gl5 non syn lube at a dealer? Mobil or valvoline full syn were 13 a qt and valvoline or Lucas non synthetic was 7. All should be gl5 rated.
  20. Oct 30, 2017 at 7:09 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    That’s why we call them stealerships.
    mrbetelman and Bravisimo like this.
