what rear drive shaft setup for 6 inch lift?pics?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 75thrangertaco, May 23, 2010.
  1. May 23, 2010 at 7:57 AM
    75thrangertaco
    75thrangertaco [OP] Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    what drive shaft setup are you using for tacos with 6 inch lift. mine looks custum . it has no carrier bearing and a slip joint towards the rear and a cv up front . im truing to see if i can use a carrier bearing type as i thing this is the cause of some vibration issues. pics pleaseor any info on where to get the proper setup . i have an 08 xtra cab with a six inch procomp drop bracket lift.thanks
