what rear end will fit my 06 tacoma ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lawrencej, Sep 30, 2012.
  1. Sep 30, 2012 at 12:06 PM
    lawrencej
    lawrencej [OP] New Member
    lawrence
    06 toyota tacoma reg cab 4x4
    3" lift
    hello
    first time toyota tacoma owner and it's great till now , i have an 06 toyota tacoma reg. cab 4x4 with a hundread and thirty six thousand miles and the rear end is leaking fluid like crazy, not thru the gaskets or seals thru the pumpkin, what rear end can i get , it does not have the lock out button , everyone tells me 01 to 04 , then another tells me an 05 or 06 will only fit. any real answers will help. thanks
  2. Dec 30, 2012 at 6:10 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    im curious as well but for an 11... are you looking to upgrade or just oem replacement?
  3. Dec 30, 2012 at 6:14 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Dang must have hit something HARD to break the pumpkin!
  4. Dec 30, 2012 at 6:44 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    My Brother once broke the welds holding one side of the pumpkin to the axle tube on a 1977 Ford LTD doing a brake stand.
    Anyways, back to the OP. Where exactly is it leaking? Pics?
  5. Dec 30, 2012 at 7:02 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    yea where is it leaking? if it has a small puncture just drain and weld it! otherwise check the torque on your 3rd member mounting.
    i would imagine any 05 up rear to fit. i believe the 4 cyls. to even use the same gearing as the 6's. check out the junkyard if you really need to. you could get the one off a trd o/r and wire up that locker lol.
    am i way off?
  6. Dec 30, 2012 at 7:13 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Yup, you are a bit off.
    4cyl 4x4s and prerunners have 4.10 gears, while the V6 4x4s and prerunners have 3.73s.
    An e-locker 3rd won't fit a non-e-locker axle housing, but you can swap the whole axle. Trouble is, you won't find a complete stock 2nd gen one with 4.10s
  7. Dec 30, 2012 at 7:33 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    what about using a tundra axle? should be pretty strong eh?
  8. Dec 30, 2012 at 8:23 PM
    92dlxman
    Kevin
    Visalia, CA
    i knew the difference between the 3rds and housings, but was clueless on the differences in gearing. thank you
  9. Dec 30, 2012 at 8:25 PM
    92dlxman
    Kevin
    Visalia, CA
    but spring perch and shock mounts are the same throughout the linup right?
