What rear shocks are you running with no lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Darty03, Jan 18, 2020.
  1. Jan 18, 2020 at 2:10 PM
    Darty03
    Darty03 [OP] •‿•
    2021 Tacoma TRD Off-Raod V6 AT
    I am getting the bilstein 5100s for the front to level my truck out but have found that the 5100s for the rear require a 1" lift. I found through searching that the 5125 shocks work in the rear with no lift but they are no longer available. What are you guys running? I hate to mix match shocks.
  2. Jan 18, 2020 at 2:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    4600's work with no lift and they're extremely affordable.
    There are plenty that run 5100's without a lift either though.
  3. Jan 18, 2020 at 2:20 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    The rear 5100s don't require any lift. They can compensate for up to 1 inch of lift, but they are designed to be run at stock height in the rear as well.
  4. Jan 18, 2020 at 2:22 PM
    Darty03
    Darty03 [OP] •‿•
    I can run the 4600s but would rather run something more similar to the 5100s as far as valving. Having a silver shock up front and yellow and blue out back would be a little annoying too lol.
    I have read on here that people had the shocks bottom out in the rear when running the 5100s with no lift. The truck is offroaded some so I'd like to avoid that. I can make the shock mounts taller to account for the longer shocks but I was hoping for something bolt in since it's stock height.
  5. Jan 18, 2020 at 2:26 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    You will not bottom out the 5100s before you hit your bump stops. They designed the 5100s to work with stock height vehicles as a simple leveling kit that is an upgrade over a spacer kit. I jumped my 2nd gen twice with the 5100s on a stock rear end and there was absolutely no damage. I've had the shocks for two years since.
  6. Jan 18, 2020 at 2:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Like I said, a lot of people run 5100's with no lift.
    Just buy these based on the part numbers -
    33-247724 21.26 EXT 13.62 COL Driver side shock
    33-247717 22.09 EXT 14.07 COL Passenger side shock
    They're just shy of 1/2" smaller than the other 5100 variants which should alleviate your fear of bottoming out.
    If you're off-roading to a much further extent than fire roads, camping, hunting, etc. then I say get yourself a lift already.
    2002Tacoma4x4 likes this.
  7. Jan 18, 2020 at 3:01 PM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Run 5100 in the rear of the 03 with no problem. It has a factory replaced leaf pack and its great.
  8. Jan 18, 2020 at 7:51 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    4600s
    Area51Runner likes this.
  9. Jan 19, 2020 at 3:07 PM
    Good deal
    Good deal Well-Known Member
    Texas
    Running Gabriel Proguard 61500. No complaints.
  10. Jan 19, 2020 at 3:45 PM
    Darty03
    Darty03 [OP] •‿•
    I will go with the 5100s front and rear. Thanks a lot for the help! I just bought this truck and actually just found that the previous owner of the truck had the rear shocks backwards so it mads for a weird feeling over bumps since one side didn't have down travel and the other bottomed out to soon. Not sure how they didn't realize something wasn't right after installing them.
