What rim and tire size should I use for a 2003 taco with total chaos LT
Discussion in '1st Gen. Tacomas (1995-2004)' started by nolant2014, Apr 1, 2016.
  1. Apr 1, 2016 at 12:42 PM
    nolant2014
    nolant2014 [OP] Well-Known Member
    Hey I just put a total chaos long travel kit on my 2003 tacoma and I wasn't sure what rim and tire size I should use, any suggestions?
  2. Apr 1, 2016 at 12:49 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    285s with a 15-17" wheel is probably what most people will say.
    More sidewall will help with off roading.
    Less sidewall ( low profile tires) will help with street performance.
    My two cents.
  3. Apr 1, 2016 at 12:54 PM
    nolant2014
    ok so 15-17 but what about tire size? what would be safe without scraping on turns
  4. Apr 1, 2016 at 1:08 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Razgriz[QUOTED] likes this.
  5. Apr 1, 2016 at 3:57 PM
    Razgriz
    San Jose, CA
    2013 White TRD 4x4
    So i do not have Long travel. I have mid travel, so i may wrong on some of the following.
    I mean 285s as the tire size. Which is a 33" diameter tire. Some will go with a 35" tire with LT. You should familiarize yourself with metric tire sizes as well. This will help.
    As far as scraping on turns, On my mid travel with 33" i was rubbing the frame, inside of the fender well and the bottom of the washer fluid bottle. Long travel may not rub the tire on the frame, I don't have LT to know for sure. I replaced the stock fenders and bedside with 4" bulge and i don't rub on the fenders anymore. Someone with LT may come along and drop some wisdom.
  6. Apr 3, 2016 at 2:43 AM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    TC site recommends a 33" tire.
    I just put their kit on my truck with 16" stock wheels (stars = 4.5" bs) with 285 Generals (33's) and I had to run my wheel spacers (1.5") in order for the rim to clear the gusseted spindle, and the tire sidewall is still relatively close to it.
    I'll prob end up picking up some new rims with 3-3.5" backspacing and ditch the wheel spacers. I havent had a chance to get a shakedown in the truck to find out if it rubs anywhere else yet.
