What rim for full size spare
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Friedtacolover, Jan 11, 2018.
  1. Jan 11, 2018 at 7:14 PM
    nartmot
    nartmot Well-Known Member
    Based on this thread, you may not need to do any mods at all.
    Also, I would go with the same aftermarket wheel as a spare. Mount it with the outside of the wheel facing up--like the way the original spare was mounted from the factory. The only part that will be exposed to damage is the inside of the wheel. If and when it is actually put to use, no one is going to see the rock chips unless they are hanging out under your truck. IMO, this is way better than running the risk of having to swap two tires every time you get a flat.
  2. Jan 11, 2018 at 7:17 PM
    Friedtacolover
    Friedtacolover [OP] Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Lol how did i not think of reversing the spare! Great advice.
  3. Jan 11, 2018 at 7:30 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Just mount a 255/80/17 on your steel spare rim. Essentially same diameter as 285/70/17 but narrow enough that it will clear your oem UCA and you can run it in the front.
    nartmot and Friedtacolover[OP] like this.
  4. Jan 12, 2018 at 12:21 AM
    phsycle
    phsycle Well-Known Member
    CA
    Get the matching rim and tire and do a 5-Tire rotation. This is pretty common.
  5. Jan 12, 2018 at 10:03 AM
    nartmot
    Then you'll have to worry about the spare not having a TPMS. I remember reading that the on board computer only supports 4 sensors so even if you buy a 5th, youll need to reprogram it every time you rotate your tires.
    I actually really like @swissrallyman 's idea. Totally thinking outside the box on that one. If I hadn't already purchased a spare tire and wheel, I would go this route to save some cash and to sell my OEM wheels and tires as a complete set.
    shakerhood likes this.
  6. Jan 12, 2018 at 10:19 AM
    phsycle
    CA
    Good point on the TPMS. Hadn't thought of that.
    You actually don't even need to worry about UCA clearance with the steelie. If you blow a front tire, just swap a rear tire up front, and run the spare in the back. Back when I had a family sedan, that's what you were supposed to do with the donut.
    Friedtacolover[OP] likes this.
  7. Jan 13, 2018 at 10:17 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I have the t4r trail wheels 17 x 7.5 with +15 offset and 265/70/17 KO2 tires. As soon as I mounted them I bought another 17 x 7.5 +15 Toyota rim and mounted a 265/70/17 KO2 for a spare. That way if I am a long distance from home the spare will not be a handling/rubbing issue on any of the 4 corners. I do carry a compressor and plug kit and, unless a tire is destroyed, I can probably plug, pump and ride without ever needing that spare. Good insurance anyway.
  8. Jan 18, 2018 at 6:52 PM
    Friedtacolover
    Travis
    Ontario, Ca
    Thank you for everyones replies. I went a full size and matching 5th rim for 350$. My reasoning-if i get a flat i can throw this on and leave it on until i find time to get to tire shop and repair it and not have to roll around looking all fudly. All responses were valid solutions. It will fit no issues in spare and im chopping exhaust after axle so pipe isnt touching tire
    11Bguy likes this.
