What rpm do you rev to when starting in 1st?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChrisGralnic, Apr 1, 2013.
At what rpm do you start off at (in traffic) not alone.
Poll closed May 1, 2013.
  1. 800-900 revs
    20.9%
  2. 1100 revs-1500 revs
    25.4%
  3. 1600-2000 revs
    10.4%
  4. 2100-2500 revs
    7.5%
  5. whatever rev gets me going in given circumstance
    34.3%
  6. whatever rev gets me going fast enough that people don't honk or cut me off
    1.5%
  1. Apr 2, 2013 at 1:43 PM
    #41
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Exactly. I just dont like when it drops below 1000 rpm when i get into 2nd gear.
  2. Apr 2, 2013 at 1:46 PM
    #42
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I think you are talking a different situation. We are talking when getting started in first gear. Reving to 2000 or 3000 after getting moving is okay. Revving to 2000 and then starting to engage the clutch is not the right way.
  3. Apr 2, 2013 at 1:57 PM
    #43
    worthywads
    Not much choice there. I only see around 1900 rpm in the cold.
  4. Apr 2, 2013 at 1:58 PM
    #44
    ChrisGralnic
    ChrisGralnic [OP] Well-Known Member
    Southern cali
    06 Prunner with AAL and Trd suspension W/lift
    Previous owner used to haul heavy loads, so he put an AAL on it and TRD front suspension with a lift and custom rear suspension for added weight capacity. I recently installed a tow package (Curt with lifetime warranty) So i will definitely see what this thing can handle as far as weight goes.
    When starting in 1st at 2000 when i engage the clutch the rpm drops to just a little over 1000. i don't feather the clutch at 2000. i raise the rpm to 2000, let off the clutch briskly enough that it drops the rpms low- but not low enough to vibrate or want to stall. never do i maintain an rpm of 2000 when releasing the clutch.
  5. Apr 2, 2013 at 2:00 PM
    #45
    ChrisGralnic
    Southern cali
    yeah i don't live in a cold area (southern cali) and my rpms are extremely high when the engine is cold. I'll have to start another thread asking if there is an adjustment somewhere that i can do myself. 2500 is a normal cold idle for my truck atm.
  6. Apr 2, 2013 at 2:01 PM
    #46
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    you're killing your clutch. it's much better to keep the RPM's bellow or at 1000 and let the clutch out a little slower.
    I actually looked at the tach for the first time ever today and I get as low as 600rpm for a split second when starting off. No vibrations or anything.
  7. Apr 2, 2013 at 2:07 PM
    #47
    ChrisGralnic
    Southern cali
    I get vibrations at about 850-900 No weight in the bed, no trailer, maybe our gearing is different. i only have 75,000 on the truck.. i keep the engine perfectly maintained and have never once abused it. ive accidentally reved it up high thinking i was in gear, but thats it. I had my flywheel resurfaced when i had a clutch TSB 7,000 miles ago. can that cause a difference in the way the clutch/engine reacts to low rpm?
  8. Apr 2, 2013 at 4:21 PM
    #48
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Nah it's probably just because you have a 4cyl and I have a V6. You just have to give it more revs due to lack of torque. I've also heard the 2nd gen manuals are really jerky and tough to drive smooth compared to the 1st gens, not sure why that would be but that could be your problem.
    Only 4cyl trucks I've driven have been a Nissan hardbody 4x4 and a GMC sonoma so no taco experience. With those I didn't have to rev above 1k to take off, plenty of torque.
  9. Apr 3, 2013 at 2:19 AM
    #49
    ChrisGralnic
    Southern cali
    Tonight I tried reving at low rpms. I just need to get in the habit because after some practice I can smoothly start out with 1000 or less rpms (as I practice ill go lower comfortably). My 4cl did fine, the uncomfortable vibrations were from being too used to letting the clutch off rather fast. When slowed down, I can easily start with little to no throttle. I learned this today in a drive thru! Lol!
  10. Apr 3, 2013 at 7:45 AM
    #50
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    :cool: your clutch will thank you.
  11. Apr 3, 2013 at 7:48 AM
    #51
    worthywads
    Now you're gettin' it. :thumbsup:
  12. Apr 3, 2013 at 8:38 AM
    #52
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    i always let my truck warm up untill the rpms drop to near normal. idk thats just me.
    i usually pump the gas as i release, heavier pumpage on incline etc... i drive better when i dont think about it
  13. Apr 3, 2013 at 11:34 AM
    #53
    ChrisGralnic
    Southern cali
    Now my only problem is I know I am burning my poor clutch when backing up my trailer uphill in between 2 cars...I'm not pro enough to be able to park my trailer fast enough that I can let the clutch all the way out.... my dad is a 25 year ASE master certified mechanic so whenever my clutch does go oj me all I need are parts. But still.
  14. Apr 3, 2013 at 11:38 AM
    #54
    ChrisGralnic
    Southern cali
    My rpms are weird when cold. Sometimes they go to about 1900, sometimes they go up to 2500 briely, then drop after about 5 or 6 seconds. What I do is let it drive itself in 1st through my neigborhood without touching the gas or shifting and that warms her up prety quickly
  15. Apr 3, 2013 at 5:41 PM
    #55
    ssault
    ssault Active Member
    Maine
    '11 TRD Sport
    URD short throw
    No option for bouncing it off the rev limiter and dropping the clutch?
  16. Apr 3, 2013 at 6:09 PM
    #56
    gearcruncher
    Canadain bumper technician
    Teaching my daughter how to drive a manual .... DO NOT touch the gas pedal whatsoever - leave it idling , let the clutch out without stalling the engine in 1st and reverse . If you were lucky enough to learn this way , you were taught properly
  17. Apr 4, 2013 at 7:42 AM
    #57
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    x2, but I will look next time. Only time I pay attention to RPMs is between gears, I love watching the tach rise and fall.
  18. Apr 4, 2013 at 7:45 AM
    #58
    2004TacomaSR5
    Jon
    Montana
    Am I missing something here? That does not seem right all and a great way to burn a clutch up. In 4 lo that is doable, but in high range? Iffy...
  19. Apr 4, 2013 at 7:53 AM
    #59
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    The v6 flywheel is heavier than the moon so that actually works pretty well for 1st. I used to do it often. Now reverse, thats different; the six speed reverse is insanely tall and clutch burn is only a matter of time.
    The four cyl definitely needs a little blip to get going but it doesn't need no 2000 rpm. About 1200-1400 on flat ground can give a swift clutch engagement that slows the engine to about 1000 or so.
  20. Apr 4, 2013 at 11:16 AM
    #60
    ChrisGralnic
    Southern cali
    Same here, I drive like a grandpa most of the time but every so often I open her up (shifting at 5,000 in second, 4500 in 3rd and 4000 in 4th) love seeing that tach!!
