What rubbing on 33's? I want to get to 285/70/17 from stock, with 2inch lift
Discussion in 'Wheels & Tires' started by MrArtixx, Mar 26, 2022.
  1. Mar 26, 2022 at 6:40 AM
    MrArtixx
    MrArtixx [OP] Well-Known Member
    2022 Lunar Rock OR Manual
    Ok, I have been doing Tire/Wheel research for the better part of a month and while I have learned quite a bit about what the numbers mean, I still have no idea what rubbing I will get with 33's. So I currently have stock wheels/tires at 265/70/16. I am looking to get up to 33's, with a bit wider tire as well. I was thinking of getting 285/70/17 which would put me where I want to be. My question/concern is the rubbing of the tire, now I do have the front lifted 2inches. I would prefer not to cut the front bumper because I am planning on getting a new bumper and selling the OEM one. The new bumper has much more clearance so its extremely unlikely it will rub. Has anyone gone to this size before with a 2 inch lift and if so what issues were had. I am assuming I will need a -12mm offset rim or maybe -18 as I do want the tires to stick out just a hair past to give it a more aggressive look. Any help would be appreciated! Also feel free to post pics of your rims/tires with sizes 285/70/17!
  2. Mar 26, 2022 at 7:32 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Aftermarket UCAs like spc will help you fit a 285. I have Icon UCAs and like them. Going to a good offroad shop for your wheel alignment is helpful as well. You can get the cmc done at the same place, around an hours Labor and you won’t even know it’s been done if they are good welders.
    its pretty easy to fit 285s and it looks great. I stuck with a C load 285 around 51lbs, mpg is still good.
    0, -10 or -12 wheels work with minimal cutting and trimming. -30 take more work.
  3. Mar 26, 2022 at 6:59 PM
    MrArtixx
    I thought that a negative offset will make it have less cutting though? And I assume the aftermarket UCA's are more about a smaller size/caster difference that helps them clear more?
  4. Mar 26, 2022 at 10:12 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    A negative offset like a -10 or a 0 offset gets the tire away from the uca so you don’t rub on it. 0 is kind of the sweet spot with 285s, they fit easier with minimal rubbing in the wheelwell.
    If you go with a higher negative offset like -30 you have to trim more. The stock tire/wheel are designed to turn within the wheel well. When you move it really far out past the fender it’s not in the wheelwell so you have to start cutting to make it fit. 0 or -10 offset the tire is mostly in the wheelwell area making fitting them easier.
    An aftermarket uca like spc makes it easier to move the tire around in the wheel well to minimize rubbing and get a good alignment after lifting.
  5. Mar 29, 2022 at 3:22 PM
    olddogventure
    olddogventure Member
    2019 Tacoma Pro
    The higher negative offset causes the OUTER edge of the tire to contact the rear portion of the fender well near or at the cab mount when the tires are turned. I found a random pic showing it, not a Tacoma but a relevant example of the geometry problem.
    So if that rim had MORE negative offset (stuck out further), that outer edge of the tire would bind with the wheel well even more.
  6. Mar 29, 2022 at 3:28 PM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    I have 295/75/16 tires with FJ wheels, 1.25” spacers, cmc and spc uppers but it wasn’t until I got my front bumper that there was no more rubbing. I had to keep trimming more and more of the front fender liner. Bumper should straighten you out.
  7. Mar 30, 2022 at 8:42 AM
    CMillTacoma
    CMillTacoma Well-Known Member
    Craig
    Colorado
    2025 TRD OR Hybrid
    So I just did a 2.25 in front lift 2 in rear lift on a 22' TRD OR SB with 17x8.5 zero offset 285/70/17 Toyo ATIII's. No UCA's as they're not needed at that lift height and I have very minor plastic rubbing in reverse that I'll simply move/heat to address when it gets warmer out. I haven't wheeled it yet so not sure on cab mount but from what it looks like If it does rub it will be minimal.
  8. Mar 30, 2022 at 8:44 AM
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    I have a -12 offset and that problem displayed in the photo is exactly what happens to me with 265/75/16s on a two inch lift.
  9. Apr 5, 2022 at 6:58 PM
    Rememberthecaptain
    Rememberthecaptain Well-Known Member
    Eastern Washington State
    2022 TRD OR 6MT Tacoma. 2021 Venture Edition 4runner
    Look and see.....
    So I'm approaching a similar situation myself. I ordered a set of 5 285/70/17 Falken Wildpeaks AT3s and am looking to buy wheels and I'm shooting for a -12 offset.
    I already have a Westcott Designs 3" front 2" rear preload collar lift that will go on the '22 TRD OR. I also have a C4 Fabrication bumper going on so rubbing in the front is a non issue. (Truck is under a week old)
    My question is, will SPC UCAs help minimize the need for cutting or trimming or am I pretty much destined for a CMC?
  10. Apr 5, 2022 at 7:03 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    You will need to slightly trim the inner fender plastic and most likely some of the front bumper. Really nothing you can do to avoid it if you want to fit 33s.
  11. Apr 5, 2022 at 7:05 PM
    JayRolla
    Colorado Springs
    You can easily fit those tires with SPCs in the F or G setting and maxing LCA bolts. I have stock UCAs and have 1/4" clearance at the cab mount. Static UCAs will not clear without chopping and cutting.
  12. Apr 5, 2022 at 7:14 PM
    SpeySquatch
    2016 TRD OR DCSB
    Getting aftermarket UCAs will make life a lot easier…it’s just smarter when running any lift and wider/taller tires. Plus some come with zercs for easy lubrication.
    seems like there is some mystery prize if you you stay stock…? If you are going to lift and mod out your front suspension components beyond anything, except looks and roaming the boulevard…why pinch pennies where it matters?
    JBA
    SPC
    Dobinson
    are all pretty affordable
    p.s. don’t forget about your ECGS clamshell bushing install when lifting beyond 1” @CMillTacoma
    tacopeter likes this.
  13. Apr 5, 2022 at 7:19 PM
    MGMDesertTaco
