What settings do you lose swapping battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Aug 11, 2023.
  1. Aug 11, 2023 at 10:38 AM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I don't use radio presets so I ain't worried about those -
    Anything else gonna go haywire if I change the battery ?...
    Buying one off the shelf and they won't install and I don't think auto-zone etc
    will swap it for me unless I buy it there.
  2. Aug 11, 2023 at 11:03 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don't recall loosing any,,, including the presets, I could be wrong,, but it certainly wasn't worth noting
  3. Aug 11, 2023 at 11:07 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    I didn't lose any. Think there's a backup capacitor or similar that stores settings for a while when battery is disconnected.
    zoo truck, Tacospike and Chew like this.
  4. Aug 11, 2023 at 11:09 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I am thinking so, that's probably why when some want to do some sort of reset (like trans shift learning) they unhook battery, and touch the negative and positive cables for min.
  5. Aug 11, 2023 at 11:10 AM
    Tacospike
    Two Trucks
    On my 3rd battery and disconnected the battery several times, never lost anything
    StayinStock, LeakyAC and tcjacado like this.
  6. Aug 11, 2023 at 11:11 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Some say you have a short window to get the new battery in. Others buy products that are attached through the cabin computer connector that sends a small maintenace charge while the main battery is out ... Crapazon, other sites, maybe even AutoZone.
    If you go with "trust the hidden capacitor", unplug all secondary devices like dashcams and cell-phone power blocks until main battery is back.
  7. Aug 11, 2023 at 11:13 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    in the end; it's not like you have a choice,,, other than to hook a charger up or something, but not sure that's a good idea, I will let an actual tech recommend that procedure.
    LeakyAC likes this.
  8. Aug 11, 2023 at 11:13 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I wouldn't recommend doing that.
    I've disconnected the battery (negative ground) more than once and don't remember any changes after reconnection.
    vivid02 and LeakyAC like this.
  9. Aug 11, 2023 at 11:15 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    good point, I sure as hell wouldn't either. I have read people doing it,,, but look at what we read around here :rofl:
  10. Aug 11, 2023 at 11:15 AM
    tcjacado
    tcjacado Well-Known Member
    Never lost a thing on the head/infotainment unit for changing or disconnecting the battery.
    Tacospike likes this.
  11. Aug 11, 2023 at 11:28 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Isn’t it just the fuel economy stuff? Like I think your average resets as if you did it manually through the eco app on the headunit?
    Thought that was something I noticed but I could be wrong
  12. Aug 11, 2023 at 11:31 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Thats good the hear these trucks have memory. When I had my gen1 tundra, every time I disconnected the battery.... even for a minute, I'd loose everything.
  13. Aug 11, 2023 at 11:34 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
  14. Aug 11, 2023 at 12:57 PM
    2021SR5V64WD
    Well I swapped out apparently no muss no fuss everything seems to be hunkydory
    Current battery was at the 2.5 year mark which in Arizona is either change it now or wait till you're stuck some place.
    I've played that game before and am not a fan.
    Battery stamped 8/23 so it's a fresh one.
    NeverStart ( everstart ) 24F (700 CCA) 3 Yr $139 Wmart..... $12.00 core
  15. Aug 11, 2023 at 1:40 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    I follow your swap it out every 30 mo. strategy religiously. Heat kills batteries here in the southwest and a new battery is cheaper than a tow truck. Also, the battery only dies at night, weekends or when you are on vacation.
    ricco333, vivid02 and Chew like this.
  16. Aug 11, 2023 at 2:02 PM
    tcjacado
  17. Aug 11, 2023 at 2:02 PM
    2021SR5V64WD
    True Dat -
    Was in YellowStone back-country a few years ago and the wife's Subaru stuttered on start up.
    Stopped at a Ranger Station to pick up a fishing license and it was totally dead.
    Had this happened where it stuttered on us we'd have made the six-O'clock news.... couple found dead in Yellowstone LOL
    The next time it happened was middle of Arizona Summer in a WMart parking lot, and I had ice-cream in tow... it wasn't a pretty sight.
    So now, we just change 'em out every 2.5 years.
    Subaru was fantastic and cut me a check for the cost of the new battery I had to put in as it was under warranty.
  18. Aug 11, 2023 at 2:57 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    On my 20 didn’t change anything after new battery swap
  19. Aug 11, 2023 at 2:58 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    You'll lose your trip information and that's about it. Especially if you're just swapping batteries
    musicisevil likes this.
  20. Aug 12, 2023 at 8:09 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think it possible to lose proper function of the power windows and sunroof with the battery disconnected, but the Owners Manual shows the procedure to reset them.
    ktbell444 likes this.
