What settings do you lose swapping battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Aug 11, 2023.
  1. Aug 12, 2023 at 8:15 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you have a compass in your mirror, the region setting for correction between geographic north and magnetic north would be lost, so you'd have to reset that again per the owner's manual.
    IIRC the 2021 SR5 didn't have automatic climate control, so no setting to lose there.
  2. Aug 12, 2023 at 9:32 AM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Ha - interesting
  3. Aug 12, 2023 at 9:50 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    When Batteries Plus put in my new AGM battery back in June they had this fancy gizmo they hooked up to the OBDII port that they said maintained power so no settings would be lost. Guess it wasn't needed, but it looked cool :)
  4. Aug 12, 2023 at 9:52 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Disconnect the Negative cable first and reattach the Negative cable last when doing the swap and you should be fine.
  5. Aug 12, 2023 at 10:14 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    an aftermarket car alarm with immobilizer might get confused
  6. Aug 12, 2023 at 12:00 PM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    Maybe attach a trickle charger to the cables while the battery is being swapped?
  7. Aug 12, 2023 at 12:01 PM
    2021SR5V64WD
    Yea it's all over now - everything worked out the only thing I had to reset so far was the tire pressure when
    scrolling the right-arrow - guess I need to check the auto-window thing had to reset that on my wife's subaru
    today when I swapped her battery. After 2 years and 2 months on a 2 year battery I was pushing it with her battery.
    Fked up thing is Napa doesn't do the swap for you anymore. It's not rocket science but at my age lifting these damn batteries
    is a bit much.
    vivid02 likes this.
  8. Aug 12, 2023 at 12:02 PM
    2021SR5V64WD
    Thought of that but wasn't sure if that would be ok to do. I'll figure it out again in 2 years LOL.
    Winch[QUOTED] likes this.
  9. Jan 19, 2024 at 10:41 PM
    Stoic_BV
    Stoic_BV Active Member
    bombee
    Sorry for the late reply, but I've been searching for an answer. I removed my stock and put an aftermarket radio. Had to reset a check light so I pulled the positive for about 10 minutes. Is it common to lose some settings on the cluster?
  10. Jan 20, 2024 at 5:54 AM
    Bglad
    Bglad Member
    Bill
    Fleming Island, Florida
    2023 Tacoma SR5 XP-Series
    Routine gas fill-ups
    The one thing I really like about Walmart. You can get a battery 24/7!
  11. Jan 20, 2024 at 7:55 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    When you are disconnecting the battery pull the negative terminal first.
    Stoic_BV[QUOTED] likes this.
  12. Jan 20, 2024 at 7:59 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I had to reset my auto door lock function (when you drive away). I had it disabled before I swapped out the Battery.
  13. Jan 20, 2024 at 8:08 AM
    Stoic_BV
    bombee
    Okay good to know for next time, I'm kind of bummed that I lost my tire pressure menu settings.
    shakerhood[QUOTED] likes this.
