What Shock length
Discussion in 'Downsouth Motorsports' started by Gianotti, Feb 6, 2013.
  1. Feb 6, 2013 at 11:24 AM
    Gianotti
    Gianotti [OP] Member
    I am going to be putting a 7-8" lift on a 2013 tacoma, and need a find a good set of shocks, so i heard you are the guys to talk to. I would like a set of Bilsteins for the rear. I cant seem to find anything that is going to fit. I will be having Alcan make me a custom leaf pack set of 8" for the rear. I would like a shock that wont let me bottom out. So If i goto flex the truck out, the shock wont stop me. Please let me know if you can point me in the right direction. thanks
  2. Feb 6, 2013 at 8:33 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Feb 7, 2013 at 8:30 AM
    Gianotti
    sent a message to them, ill see what they say!
  4. Feb 7, 2013 at 11:17 AM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Good morning,
    No 5100's that will bolt directly into the stock location.
    You will most likely need to run a 5125 in 14" Travel along with a stem conversion kit.
    The only draw back will be the 5125 is not valved vehicle specific and only carries a 90 day warranty from date of purchase.
    Let us know if there is anything that we can help you with.
    Thank you,
    Sonny
  5. Feb 7, 2013 at 11:35 AM
    Gianotti
    What other shock options do I have?
  6. Feb 7, 2013 at 12:20 PM
    Honestly....Not to many options because of the way the shock needs to mount..We maybe able to get ICON to build an emulsion shock in a 30" to 33" extended length?
  7. Feb 7, 2013 at 12:33 PM
    bzzr2
    bzzr2 Well-Known Member
    ProComp ES3000/ES9000 SHOCK ABSORBERS
    32156X 21.31 12.55 8.76 Stem (LG) Stem (LG) 2.36
    32157X 21.75 13.15 8.6 Loop (2”) Stem (LG) 2.36
    32250X 22.58 13.71 8.87 Loop Loop 2.36
    32251X 22.75 13.54 9.21 Stem Loop 2.36
    32255X 22.27 14.37 7.9 Loop Loop (2”) 2.36
    32350X 23.24 14.31 8.93 Loop Loop 2.36
    32450X 24.84 14.82 10.02 Loop Loop 2.36
    32451X 24.7 14.52 10.18 Stem Loop 2.36
    32550X 25.74 15.49 10.25 Loop Loop 2.36
    32551X 25.75 15.04 10.71 Stem Loop 2.36
    32553X 25.17 14.79 10.38 Stem Loop 2.36
    32554X 25.23 15.22 10.01 Loop (2”) Loop (2”) 2.36
    32555X 25.22 15.22 10 Stem (LG) Loop (2”) 2.36
    32600X 25.99 15.39 10.6 Loop Loop 2
    32650X 27.07 15.94 11.13 Loop Loop 2.36
    32651X 26.79 15.56 11.23 Stem Loop 2.36
    32750X 27.76 16.27 11.49 Loop Loop 2
    32751X 27.29 15.8 11.49 Stem Loop 2
    32950X 29.83 17.32 12.51 Loop Loop 2.36
    32951X 29.77 17.09 12.68 Stem Loop 2.36
    33200X 32.83 18.82 14.01 Loop Loop 2.36
    33201X 31.76 18.25 13.51 Stem Loop 2.36
    33400X 34 19.42 14.58 Loop Loop 2.36
    33600X 35.88 20.36 15.52 Loop Loop 2.36
    not sure if this will be of any help but 31.76 extended is something like 9-10inches longer than stock and should mount to stock mounts, compressed at 18.25 should be just fine with that monster leaf pack
  8. Feb 7, 2013 at 12:38 PM
    There you go Pro Comp it is....
    Handled...
  9. Feb 7, 2013 at 8:28 PM
    bzzr2
    hey, didn't realize this was in vendors section, didn't mean to jump in your thread.
  10. Feb 7, 2013 at 9:04 PM
    No worries...
    Good that you found a shock with those dimensions...
    No harm no foul...Its all good...
    Thank you,
    Sonny
