What Shocks with your 2" rear lift
Discussion in 'Suspension' started by rawdog, Jan 14, 2013.
  1. Jan 14, 2013 at 11:54 AM
    rawdog
    rawdog [OP] Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Hey guys,
    I put a 2" block in my rear, I'm looking for new shocks because my stock ones are not long enough and clunk when my leaf goes to full droop.
    What shock did you use that you have no problem bottoming or topping out with?
  2. Jan 14, 2013 at 12:21 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Not sure what the difference is in length over stock, but I hear folks running the 5100s with a 2" lift in the back.
    Perhaps even shock extenders would work, I know Toytec sells some.
  3. Jan 14, 2013 at 12:25 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I wouldn't listen to anyone on the web regarding what size shocks I need. I have done that in the past and lets just say it doesn't always work.
    Now I am a little wiser so I would grab a tape measure and do it right the first time. See here http://www.shockwarehouse.com/news/how-to-measure-shocks.cfm
  4. Jan 14, 2013 at 12:42 PM
    rawdog
    Kelowna B.C.
    I am literally outside right now with my computer and my truck jacked up
    going to buy the bilstein B110 5100.
    Should fit perfect, or i might have to mod my factory bumpstop a tiny bit
  5. Jan 14, 2013 at 12:46 PM
    Mr Salty
    Hermmy
    Lots of chrome
    As would I, its the common sense approach to take ;)
  6. Jan 14, 2013 at 12:49 PM
    Mr Salty
    Hermmy
    Lots of chrome
    If those are the RCD branded 5100s which were designed to work with 4" blocks, you will def have to modify the bumps. Keeping in mind doing so will come at a lost in up travel. Those shocks are long!
    Best of luck
  7. Jan 14, 2013 at 12:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Standard travel 5100's for me. I haven't bottomed them out. I'm sure I've topped them out since I have floated a tire but it wasn't a hard top out. I'm not running blocks though, I'm running an AAL. I agree with XXXX's suggestion about measuring for best results.
  8. Jan 14, 2013 at 12:53 PM
    Pugga
    Massachusetts
    The Bilstein B-110's are the ones recommended for 3-4" of lift. Might be a little tall for a 2" block but people are running them with 1.5" AAL's...
  9. Jan 14, 2013 at 12:56 PM
    rawdog
    Kelowna B.C.
    Yes, but
    I just measured and it came out to 16.5" compressed length and 24.5" extended length
    the b110's dimensions are 16.34" compressed length and 27.28 extended length
    does that not sound pretty good to you guys?
  10. Jan 14, 2013 at 12:57 PM
    rawdog
    Kelowna B.C.
    the extended i shouldn't have to worry about at all, and the compressed, lets say my measurements are off by an inch i'd still only need to mod my bumpstop to lengthen it by 3/4" max
  11. Jan 14, 2013 at 12:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That couldn't have been too comfortable
  12. Jan 14, 2013 at 1:00 PM
    rawdog
    Kelowna B.C.
    hell no!
  13. Jan 14, 2013 at 1:00 PM
    Pugga
    Massachusetts
    What did you measure? You should be measuring from eye to stem at full droop and full compression.
    You might not have to modify the bump stops at all since you're using a block lift. If you lifted using an AAL, you're bump stop would be sitting 2" lower but the blocks keep the bump stop close to the frame and just drop the axle.
  14. Jan 14, 2013 at 1:03 PM
    rawdog
    Kelowna B.C.
    I measured from center of the eye to the bottom of the stem on top of the shock.
    both shocks disconnected, one side at full droop other side touching bumpstop
    I've done it 3 times in the last few days haha.
    I wish that was the case about the bumpstops.. but my measurements tell me otherwise.
  15. Jan 14, 2013 at 1:10 PM
    Mr Salty
    Hermmy
    Lots of chrome
    Yeah 3"-4" is about right. I think most companies say this understanding 3" for one truck could be more like 3.5" for another; there’s so many factors contributing to actual lift height not to mentioned product tolerance.
    It’s funny though because I’ve seen these advertised to be good for 2”-4", which I think is BS. I actually spoke to an RCD rep a ways back and these shocks are for their 4" blocks that go with their 4.5" lift kit.
    I my opinion a safe shock for a 2” lift would be the Bilstien 5160s. The collapse length due to the resi is actually shorter then the 5100s and the extended length is almost a ½” longer. Yet I’d still measure first, but pretty sure they would be a good fit for a 2” lift just based on numbers alone.
  16. Jan 14, 2013 at 1:12 PM
    Pugga
    Massachusetts
    With a block style rear lift, you shouldn't have to extend your bump stops... On the stock leaf pack travel, there's hardly any up travel at all. Your up travel has not changed. People have to extend their bumps because they use AALs or a different leaf pack which puts the bump stop further down, closer to the axle. Just sitting at rest, how much room do you have between the top of the bump stop and the frame?
  17. Jan 14, 2013 at 1:20 PM
    rawdog
    Kelowna B.C.
    Pugga You are right about the bumpstop and how I shouldnt have to change it with only a block, however, since the b110's have a longer than stock compressed length, I would have to modify my bumpstops.. the stock compressed length i have is 16ish and the shock is 16.34.. pretty close closer than the stock shock I would assume
  18. Jan 14, 2013 at 1:37 PM
    Pugga
    Massachusetts
    Well, you're doing the right thing by measuring. If the measurements tell you to extend the bumps, then extend the bumps. Next thing, don't forget about the brake lines. Make sure they can handle the extra droop.
  19. Jan 14, 2013 at 1:41 PM
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    I have OME N182 shocks in the back with a 2" AAL, works great.
  20. Jan 14, 2013 at 1:50 PM
    rawdog
    Kelowna B.C.
    just ordered B110's from North shore off road in vancouver
