what shocks
Discussion in 'Suspension' started by taco_man, Feb 24, 2010.
  1. Feb 24, 2010 at 3:35 PM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    what kind of shocks should i go with. i have a total of 7 inches of lift but im wondering what shock to put in the rear that wont be maxed out. i also what good quality. something with a reservor maybe?
  2. Feb 24, 2010 at 3:40 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    fox, Icon, Bilstein
  3. Feb 24, 2010 at 3:41 PM
    taco_man
    Austin
    Houston
    09 texas edition
    im thinking bilstein cuz i dont want to break the bank spending 500 a shock. but i need to know which one will be long enough
  4. Feb 24, 2010 at 3:43 PM
    dylandercole
    Dylan
    I knwo I got my bilstein 5125s in a custom length but they arent resevoir. Im not 100% but I think Icon and Fox can do custom lengths as well
  5. Feb 24, 2010 at 3:44 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    bilstein 7100's have the resis I think.
  6. Feb 24, 2010 at 3:45 PM
    taco_man
    Austin
    Houston
    09 texas edition
    im not to worried about the reservor just want a good quality one that wont blow out. yall know what i mean??? and are shocks adjustable or does it matter on how much they are compressed???
  7. Feb 24, 2010 at 5:43 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what do you have that are you at 7 inches of lift?
    what is your rear lift combo?
    the bilstein 7100s are 2.0s and come in different travel lengths from 8" to 14"
    im running 7100s in 12" travel in my rear end... collapsed they are 16" long and at full extension, they are at 28"
    you need to cycle your rear suspension with the shocks off to see what your collapsed length and full droop length would be, then find the right travel shocks for your suspension...
    or you can guesstimate...
    stock height is 6.5" travel, typical AAL or shackle lift is 8 to 8.5" travel, mid travel lift is 8.5" to 10" travel, mid travel on steroids (my own term) is 10" to 12" travel, and then long travel sets you into 14" to 18" travel...
  8. Feb 24, 2010 at 5:46 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    im running the version with the reservoirs... in valving "04" which is 255/70...
  9. Feb 24, 2010 at 7:31 PM
    taco_man
    Austin
    Houston
    09 texas edition
    im running the dakars and a inch block in the rear. then 4 inch camburg spindles up front with ome 885
  10. Feb 24, 2010 at 7:40 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    you should be fine with 10" travel shocks in rear...
  11. Feb 24, 2010 at 8:36 PM
    taco_man
    Austin
    Houston
    09 texas edition
    woops i meant to say a 4 inch block in the rear.
  12. Feb 24, 2010 at 8:48 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    definitely need to cycle that suspension... im guessing a 12" should be enough though...
  13. Feb 24, 2010 at 8:50 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    also with the dakars, i would ditch the blocks and do a shackle flip kit with custom shackle instead... you would gain your lift height, but gain more travel and better flex and a more caddy of a ride...
  14. Feb 24, 2010 at 8:53 PM
    taco_man
    Austin
    Houston
    09 texas edition
    i like that idea. never did like blocks. but wouldnt i need to re rought my exhaust?
  15. Feb 24, 2010 at 9:08 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    with the increased travel, yes but its worth the ride...
    on our wheeling rigs we cut the pipe just before the axle... looks ghetto but its function over form...
    i seen some rigs reroute the pipe above level of the frame to avoid the axle
  16. Feb 24, 2010 at 9:11 PM
    taco_man
    Austin
    Houston
    09 texas edition
    well this is a daily driver and my mom payed for the truck and i dont think she would be happy if i went without a tip so i will be re routing but thats no biggie. but back to the shocks. what do you think i should run??? ad would you re route the shocks to more of the middle of the axle?
  17. Feb 24, 2010 at 9:19 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    im runnin 12" shocks on my setup... didnt relocate the shocks...
    u should be fine in stock location...
    u would be good with 12" short body 7100s
  18. Feb 24, 2010 at 9:32 PM
    taco_man
    Austin
    Houston
    09 texas edition
    what does relocating the shocks do???
  19. Feb 24, 2010 at 9:42 PM
    ColesDirtyYota
    ColesDirtyYota Well-Known Member
    Cole
    San Diego
    Dezert Built
    Camburg LT Icon 2.5" x 9" coilovers Radflo 2.0" Bumpstops Radflo 2.5" x 16" tripple- Bypasses Deaver F67 Race Pack Richer Racing 12" shackles Full bedcage Full 2" cab cage Tube bumper Solid motor mounts Total Chaos spindle Gussets RR gusseted UCA mounts Total Chaos poly urethane Steering kit T100 axle 4:88's/ Locker AFE dry air intake BA Muffler Trimmed the Throttle Body Fiberwerx 05+ clip Fiberwerx 8" bedsides Full JL speakers/ deck/ sub Rigid Industry 30" LED bar ORW LED amber lights/ brake lights Kenwood Race Radio HF jack with custom skid plat
    Hear is an example of why u would, if u want shock mounts in your trucks bed for long travel so u can run 14" shocks or other large sizes u have to relocate them becasue the stock location is not as secure and would not work with a cage or large shock mounts in the bed of the truck, so ud have to weld new shock mounts on the axle. Thats as basic as i can say it. For LT, stock locations wont cut it.
    But for a set of replacement shocks like billy 5100 or a bit larger, your totally fine
  20. Feb 24, 2010 at 9:47 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    for rockcrawlers, /\ helps with articulation... mybuddy's truck is setup that way... it flexes really well...
