What should I do about this rust?
Discussion in 'Detailing' started by BassMaster06, Aug 22, 2010.
  1. Aug 22, 2010 at 10:04 AM
    BassMaster06
    BassMaster06 [OP] Well-Known Member
    Dan
    Lady's Island, SC
    Sand and dog hair
    Hey, I have a black 06 tacoma. I'm surprised at the amount of rust accumulating on the frame already. They use a lot of salt on the roads in the winter time, so I know that's probably the main cause. What can I do/should I do about it? Its definitely an eye sore? I want to get rid (cover up?) the rust and protect the frame at the same time.
  2. Aug 22, 2010 at 10:20 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    sand it then rustolium hammer finish, touch up when needed or every 6 months
  3. Aug 22, 2010 at 10:32 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    get a angle grinder with some brillo style disks on it, have at it.... i would put down a coat of rust reformer first than whatever rattle can u desire
  4. Aug 22, 2010 at 10:34 AM
    Brunes
    Brunes abides.
    Rotorhead
    Rust reformer/converter is the key. Most of that looks like surface rust-so it is a non-issue to clean it up. Get it sealed right and you'll be good to go.
  5. Aug 22, 2010 at 10:46 AM
    LtHixson
    LtHixson My Other Truck is an Engine
    Lubbock, Texas
    Super White 2014 Tundra DC 4x4 TRD SR5
    Tailgate Theft Prevention Mod
    I have this same problem with my 06, and I think I'm going to try the rust reformer, too. If you try it, let me know how it turns out, and I'll do the same for you.
    Good luck!
  6. Aug 22, 2010 at 11:12 AM
    BassMaster06
    Dan
    Lady's Island, SC
    Sand and dog hair
    Thanks for the replys. Whats the difference between Rustoleum Hammer Finish and Rust Reformer?
  7. Aug 22, 2010 at 1:34 PM
    Burgman
    Stephen
    Ric VA
    rust reformer is made to stop rust from "rusting" or oxidizing metal, regular paint isnt going to do that... you dont have to sand down the frame but u need to make sure there isnt any loose flakes that will stop you from getting the rust reformer on all the exposed metal
    GL
  8. Sep 2, 2010 at 7:58 AM
    BassMaster06
    Dan
    Lady's Island, SC
    Sand and dog hair
    do you think a wire brush would suffice to getting loose flakes off, instead of a use an angle grinder/sander?
  9. Sep 2, 2010 at 8:04 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Holy shit, thats alot of rust for an "06".
  10. Sep 2, 2010 at 8:22 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just go pick up an angle grinder from wal-mart. I bought my black&decker from wal-mart for $25. Your arms will thank you.
  11. Sep 2, 2010 at 9:00 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Amsoil Heavy Duty Metal Protector works really well on the frame and other parts to stop and prevent rust. It sprays on oily so it seeps in cracks, but it dries clear. And it acts as a lube so I sprayed everything except electrical connections on my underbody. Did it on my '01 chevy and it still has minimal rust to this day. Minnesota winters...
  12. Sep 2, 2010 at 9:31 AM
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    Not really. It depends on where you are. Up north there is salt/gravel and snow on the roads for 5-6 months of the year. Unless you are fanatical about crawling under your vehicle every couple days to clean it, that's what it looks like.
  13. Sep 2, 2010 at 9:46 AM
    BassMaster06
    Dan
    Lady's Island, SC
    Sand and dog hair
    Yea, it sucks...but not much I can do. This past winter was real bad cuz of the two blizzards that hit the northeast. Salt/Sand is brutal on a vehicle
  14. Sep 2, 2010 at 3:22 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Are sparks and gas fumes an issue?:eek:
  15. Sep 2, 2010 at 3:25 PM
    macgyver
    Brad
    Canton, GA
    Well there shouldn't be gas fumes...otherwise something is wrong with the EVAP system and/or tank. There would only be sparks if you used a grinding wheel. Using abrasive pads should result in little to no sparks.
  16. Sep 2, 2010 at 3:39 PM
    mandzach
    mandzach Well-Known Member
    This works, did it to my trucks back in upstate NY.
  17. Sep 3, 2010 at 2:12 AM
    coffeesnob
    VA
    OK thanks, guess I associated when he asked about using a wire brush then angle grinder etc..
