What should I do to my 99 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by kwackin, May 9, 2017.
  1. May 9, 2017 at 9:57 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    This is a good point. After the lift and wheel upgrade, I now want everything down there strong and reliable, including my brakes. I'm trying to be more "safety and reliability first" and not get distracted by shiny objects. My ADD doesn't help.
  2. May 9, 2017 at 10:03 AM
    2BeersPlease
    Let's just hope he didn't get 20" rims. :pray:
    Ceddingermtb likes this.
  3. May 10, 2017 at 5:57 AM
    kwackin
    kwackin [OP] Active Member
    99 Tacoma extended cab sr5 4x4
    this is my daily driver, and im going to try to keep in on the road as much as possible. However, i dont think that's going to happen lol
  4. May 10, 2017 at 7:43 AM
    kwackin
    I got fuel anza 15x8 with 31x10.50 mickey thompson baja mtz
  5. May 10, 2017 at 7:44 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Once you've taken care of the preventative maintenance and got her reliable, my vote is for armor; sliders, bumpers and skids. Then recovery gear...
  6. May 10, 2017 at 11:15 AM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    If you don't plan to wheel, save yourself a lot of money both in parts and gas and don't armor up your truck.
    Assuming basic maintenance is already done, and this is mainly a DD on road truck, I'd recommend:
    Tundra brake swap.
    New suspension (EMU for a budget, Kings etc... if you want a better ride quality)
    New Leaf pack
    UCAs if you lift 2.25+"
    Retrofits
    New seats (I swapped 97 4runner seats, way more comfy)
    Shell if you store stuff in the back and need it secured.
  7. May 10, 2017 at 2:21 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I used to have crank windows, manual locks, and manual mirrors. I've done a lot of mods to my truck but adding in power windows, keyless entry, and remote mirrors is by far one of the best mods I've ever done. Cost me under $400 to attain all the OEM components, and supplies. I built a harness to adapt to the OEM Toyota door harnesses, and created a control box to replace the integration module and RS3000 module the truck would normally use. It's pretty simple, just a couple of relays and fuses and a ton of soldering and wire routing.
