What should I do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChompsterTacoma, Oct 19, 2010.
  1. Oct 19, 2010 at 10:23 AM
    ChompsterTacoma
    ChompsterTacoma [OP] Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    So I drop my truck off this morning for oil change and for other minor problems. Service advisor said there is a recall for gas pedal, floor mat, and flash. But I kindly said no. No papers to sign. Then I ask for the steering and leaf spring tsp be done and he said they have to find out if there is a problem first. Then I ask how is he going to find a problem with steering rattle if it only happen on fire roads? He said if they don't find a problem then they won't fix it. He did not even look at my tsb papers. So what should I do? Take this up to service manager?
  2. Oct 19, 2010 at 10:27 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    If you're having a problem with the steering column rattling they should fix it under warranty, regardless of any TSBs. Is this something you experienced or something you read about? Same with the leaf springs. If you don't have an issue with the truck, they're not going to do anything about it. It costs them money to perform the work so they're not going to do it unless it's needed. If your truck is bottoming out with a load it in, then you've got a case and you'll need to either take it to the service manager or call Customer Service.
  3. Oct 19, 2010 at 10:38 AM
    ChompsterTacoma
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    It is all that I am experiencing. I never knew there was a fix for it prior to the problem. Until I started digging around to see if that is normal.
  4. Oct 19, 2010 at 10:41 AM
    ChompsterTacoma
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    I told the service guy that you can see where the bump stops hit and he said that is what it is for and I ask, so hitting the bump stop all the time is normal? He said yup. I started to scratch my head on how dumbo this guy is.
  5. Oct 19, 2010 at 10:42 AM
    Pugga
    Massachusetts
    I'd go back to deal with the service manager and, if that doesn't work, customer service. Sometimes it takes some coaxing... I've heard stories of people taking the service manager for a ride along in order to convince him the TSB needed to be performed. Hopefully they have a decent service manager and can get it done for you without too much of a headache.
  6. Oct 19, 2010 at 10:43 AM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    You shoulda took the flash.
  7. Oct 19, 2010 at 10:52 AM
    Pugga
    Massachusetts
    Yeah, what he said... time to get a little meaner if the dealership is really that ignorant. You can try the service manager but when that doesn't work, follow what Oswego said.
  8. Oct 19, 2010 at 10:57 AM
    ChompsterTacoma
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    Service told me flash is part of the recall package. Gotta do all of it.
    I'll call the service manager. Thanks for the support!!!! Love this site!!!
  9. Oct 19, 2010 at 3:56 PM
    ChompsterTacoma
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    So I just picked up my truck and talked to the service manager and he said the obvious. Can't duplicate so we can't fix it. Time to call Toyota.
  10. Oct 27, 2010 at 9:09 AM
    rdrnr
    rdrnr Member
    I just had my first oil change at the dealer and was asked to do the pedal recall and computer flash. I declined because I didn't think it right to cut the pedal when it should be replaced. My Tacoma is a late 2010. I decided to call Toyota and ask for a new pedal instead of the "cut job". I was informed that my truck was not part of the recall!!!!!!! So make sure your truck is included in the recall before having this done. Do Not Rely on the Dealer
