What should the charge be for a complete brake fluid flush and fill ?
Discussion in 'Technical Chat' started by Soylent Green2012, Dec 18, 2020.
  1. Dec 18, 2020 at 2:53 PM
    Soylent Green2012
    Soylent Green2012 [OP] RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    Hey guy's, So my truck has 83K on it now and I will be doing a brake upgrade
    in the future . So what would be a reasonable charge to have a complete brake fluid flush
    at a local repair shop? Not a dealership.
    Maybe $100 - $200 ?
  2. Dec 18, 2020 at 3:21 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Sounds about right. My dealer charged $110 included fluid.
    whatstcp likes this.
  3. Dec 18, 2020 at 3:25 PM
    Soylent Green2012
    jake
    Apopka, Florida
    I figured maybe $150 was a good deal. I may go ahead and have the rear shoes
    and drums checked as well. I do have a pair of 5100's I need to install, wonder about
    a package deal maybe ?
    The front rotors and pads are easy enough to do myself.
  4. Dec 18, 2020 at 3:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Beware brake fluid flush is typically separate from any other brake service in terms of pricing, because you can do the flush without even removing the rear wheels.
  5. Dec 18, 2020 at 3:39 PM
    Soylent Green2012
    jake
    Apopka, Florida
    Well I would assume the rear wheels are going to be off for the inspection anyway.
    The separate cost does not bother me. I just do not know how old the fluid is.
    I need to set a bench mark for having the fluid changed. Then I know how
    long to wait to do it again in the future. Drum brakes are just not my thing.
    I've done plenty of disks, But always get the rear drums done by a shop.
  6. Dec 18, 2020 at 6:09 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Older Toyota maintenance booklets say brake flush every 4 years. Newer booklets say every 3 years. Suggest you use Toyota-branded fluid as it contains lubricants for the master cylinder seals.
  7. Dec 19, 2020 at 5:13 AM
    Soylent Green2012
    jake
    Apopka, Florida
    Well the truck is 8 years old and the history only shows it was serviced by a toyota dealer
    and it's not specific to if the brake fluid was ever flushed. I assume it was not.
    Even if it was done once most likely it's due or overdue to be done again.
    I would much rather assess the brakes after the fluid has been changed. At least
    then I can gauge how effective the new brake parts are.
  8. Dec 19, 2020 at 5:18 AM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    I had mine done by my independent shop - $120. So your estimate is good. At 8 years old your truck is ready for a fluid change.
  9. Dec 19, 2020 at 5:31 AM
    Soylent Green2012
    jake
    Apopka, Florida
    So did you only get the fluid flushed with no other work performed ? and how did the braking
    improve ?
  10. Dec 19, 2020 at 10:43 AM
    taco_rhyno
    06 DC 4x4 Sport
    A brake flush isn't to improve your normal braking. Over time your brake fluid absorbs moisture from the atmosphere. This lowers the boiling point of your brake fluid. Then, if you really work you brakes hard the hot calipers boil the fluid and your braking becomes non-existent. It's a safety-related maintenance item.
    Yes, shops will do brake flush only. I do most of my own brake work otherwise.
  11. Dec 19, 2020 at 10:49 AM
    Soylent Green2012
    jake
    Apopka, Florida
    Yes I'm fully on board with Hydroscopic fluids. Me too on the brake work but this is a messy
    job for just one honcho. Easier to let the guy I know locally to do it for me. He's pretty
    good and honest .
