What size 5150s?
Discussion in 'Downsouth Motorsports' started by NumNutz, Feb 1, 2010.
  1. Feb 1, 2010 at 6:09 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    What size 5150s do I need to get for my 07 Tacoma with the Toytec TSB AAL?
    Thanks.
  2. Feb 6, 2010 at 5:10 PM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Did you get our PM?
  3. Feb 6, 2010 at 5:14 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Interested
  4. Feb 6, 2010 at 5:58 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Negative
  5. Feb 7, 2010 at 8:50 AM
    Good morning,
    This is Sonny,
    The 5150's will need a stem conversion kit in order to run them on the Gen.2's and
    or Bilstein has a stem conversion kit as well for the 5150's.
    The 5150's are not vehicle specific and are sold in different lengths of travel..
    The closest length would be 10" Travel 5150's and here are the dimensions:
    Ext.Length:25.91"
    Col.Length:15.89"
    It is on the verge of being to long on its compressed length and once you add in a stem conversion kit if you choose to do that over the Bilstein stem kit it add
    1.5" to the overall lengths...
    The 8.5" Travel would most likely be your best bet with the following dimensions:
    Ext. Length: 22.50"
    Col. Length: 14.17"
    Then add a Pro Comp Stem conversion and that should be close.
    Hope this helps....Also 255/70 valving..
    Thanks
