What size alternator fuse do you have with your tow package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gus87, Aug 27, 2019.
  1. Aug 27, 2019 at 6:34 PM
    Gus87
    Gus87 [OP] Well-Known Member
    Chicagoland
    16 trd sport
    I upgraded my alternator to the tow package one, I think it's 130 amps. I plan on upgrading the 100 amp fuse soon. But when I look for what size fuse to replace it with i see 120 and 140 amp fuses so I didn't know if anyone knew the answer as to why and if you guys could let me know what size your fuse is. Thanks in advanced.
  2. Aug 27, 2019 at 6:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe it is 140A w/towing package
    120a with out
    Gus87[OP] likes this.
  3. Aug 27, 2019 at 6:56 PM
    Gus87
    Chicagoland
    16 trd sport
    Thank you. Idk what I was thinking. I swore I had a 100 amp. I do have the 120. I was just confused cuz I didn't think the fuse would be a higher amperage than the alternator.
  4. Aug 27, 2019 at 7:01 PM
    GreenYoda
    GreenYoda Well-Known Member
    When my alternator went south, and I was attempting to diagnose the problem, I noticed that the fuse is not easy to remove. I like to pull them and ohm them to test them. I never got it out, and I'm still not sure what it would take to replace it. In the end I had the alternator rebuilt and that fixed the problem. I have the 2009 tow package and it is 140 amp.
    Is there a reason you upgraded the alternator? I think the reason the factory tow package has the bigger alternator is because you can provide power to whatever you are towing. Unless you have a need for it, what is the extra 20 amps going to do for you?
  5. Aug 27, 2019 at 7:06 PM
    Gus87
    Chicagoland
    16 trd sport
    I found a thread on here in how to change the fuse and it's not too bad. I plan on doing a decent amount of electrical add on's so would rather have the extra power.
  6. Aug 27, 2019 at 7:09 PM
    TnShooter
    Deogee
    STOCK
    You have to partially disassemble the fuse box.
    Probably not too bad to do. Just be careful and you should be ok.
  7. Aug 28, 2019 at 6:11 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
