What size axle shim for regular cab?
Discussion in 'Suspension' started by 90YotaPU, Oct 28, 2011.
  1. Oct 28, 2011 at 5:00 PM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    So I installed an AAL and cranked the 5100's up to 2.5. Now I'm getting a vibration at highway speeds and when coasting downhill with foot off throttle, I'm getting a noise that almost sounds like a strong crosswind. My question is: what size axle shims do I get (2 or 3 degree)? Any other recommendations? Also, can I reuse the existing leaf spring bolt (the one that holds the leaf pack together or do I need one with a larger head?
    I've attached some pics of my angle at the rear end and at the transfer case.
  2. Oct 28, 2011 at 5:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Make sure the U bolts are torqued to 80# or so. Most vibes come from not torqing the bolts and nuts tight enough.
  3. Oct 28, 2011 at 5:04 PM
    90YotaPU
    Union County, NJ
    Thanks for the quick response. I will double-check that. I know it's hard to tell from the pics but do the angles look bad? I was reading that the angle on both ends of the driveshaft should be equal but don't fully understand it.
  4. Oct 28, 2011 at 5:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The angle doesnt look too bad, regardless, I havent had vibes on any vehicle when the bolts were all torqued propperly. No shims needed.
  5. Oct 28, 2011 at 5:18 PM
    90YotaPU
    Union County, NJ
    Thanks. If I ever meet you I owe you a beer. You've helped me so many times.
  6. Oct 28, 2011 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cheers:
