what size generator do I need?
Discussion in 'Off-Topic Discussion' started by takaya49, May 2, 2011.
  1. May 2, 2011 at 5:45 PM
    takaya49
    takaya49 [OP] Pacific Rim Mushrooms
    Brent
    Vancouver BC
    tacos
    Fox C/O long travel shox with resi, piggy back fox rears, TC UCA's, ICON AAL, Addicts/17 toyo MT, Mr. Marv set up,
    im running 2 large fans. they are 30 amp and 1 hp each
  2. May 2, 2011 at 6:28 PM
    fj6high
    fj6high Well-Known Member
    Howard
    Tarpon Springs
    07' Fjcruiser
    6"Fabtech +OME Heavies and Custo Skyjackers. Way to much to list.
    If your talking about 110 V fans? You will need at least a 5K generator to run them at full speed or load at the same time. Most 5K generators max at 50 amps...If that helps.
  3. May 2, 2011 at 7:57 PM
    btuner
    btuner <<<<>>>>
    Brandon
    Hendersonville NC
    09 PreRunner SR5
    Stage III TRD Badge
    34 inches across, 24 inches deep, and 18 inches wide... Those are the exact dimensions of what you need
  4. May 3, 2011 at 6:23 AM
    cereal.killah
    cereal.killah got milk ?
    1 hp= 746 watts
  5. May 3, 2011 at 6:32 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    A 1 hp motor draws a hell of a lot more than 746 watts on start up. A 1/2 hp water pump takes every bit of my 2000 watt gen. So for 2 1hp fans you're gonna need at least 8000 watts.
