What size is my crank bolt?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hallisi, Mar 7, 2023.
  1. Mar 7, 2023 at 7:07 PM
    Hallisi
    Hallisi [OP] New Member
    2.7 2008 Tacoma
    Getting ready to do head gasket. anything I should be aware of any informational timing marks or stuff I should be aware of. Also the main question is what size is my crank nut. I would like to give this baby a leak down text before. To make sure 100% blew the head thank you taco gurus
  2. Mar 7, 2023 at 7:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    22mm I believe
  3. Mar 7, 2023 at 7:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What is the truck doing that you believe it’s the hg?
    Hallisi[OP] likes this.
  4. Mar 8, 2023 at 1:16 PM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    If you are asking questions about anything you need to know about timing, are you sure you're ready to take on doing the head gasket/s?
    zguy1 likes this.
  5. Mar 8, 2023 at 1:20 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    You really want to be certain of both your diagnosis and of your repair procedures before just diving into a HG replacement.
    Watching parts 1 & 2 of BOTH of the videos below will give you approximately 4,536% more information about HG diag & replace than you'll get from random replies here in this TW forums thread.
    Good luck.
    Head Gasket Diagnosis:
    https://www.youtube.com/watch?v=uVn-IDi7da8
    Head Gasket Replacement:
    https://www.youtube.com/watch?v=06l5jHMZt0Y
