What size is the Icon coilover lower uniball?
Discussion in 'Suspension' started by rzimm001, Apr 10, 2010.
  1. Apr 10, 2010 at 8:33 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I bought my shocks second hand and they are in need of a new lower uniball. This is the joint where the shock attaches to the lower control arm with a bolt and nut. That small lower uniball is sloppy and I need to know what size it is so I can acquire a new one from ORW or similar. Any ideas on the size?? Thanks
  2. Apr 10, 2010 at 8:45 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  3. Apr 11, 2010 at 12:16 AM
    rzimm001
    Bobby
    Wildomar
    Thank you. Is the top one a 5/8 as well? I noticed it only listed one bearing size and didn't say whether it was a lower or upper...:confused:
  4. Apr 11, 2010 at 2:07 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    IDK if the top is 5/8" as well but i know the bottom is 5/8". good luck
  5. Apr 12, 2010 at 2:11 PM
    adrn1986
    adrn1986 Well-Known Member
    Adrian
    Riverside Ca
    04 Pre-Runner
    -Icon Coilovers and Bypasses -LT Front and Rear -Supercharged
    Both top and bottoms are 5/8" for all Tacoma models.
    5-8610's, 15's, 30's and 35's.
  6. Mar 11, 2012 at 12:25 PM
    Ryan07
    Ryan07 Well-Known Member
    New Brunswick
    07 TRD DC,LB Sport 4x4
    Icon Ext. Coilovers, LR UCA's, Icon AAL, Nitro 9000 Shocks, 7"Kragen HID's/Billet Grille, Extang Solid Fold Tonneau Cover, Bed Lights, Diff Breather Mod, D-Rings Mod, LED Interior Lighting/Plate Lights, LED 4X4 Switch, Viper Starter, AVH-P4200DVD, PAC Interface, OEM Backup Camera/Pop&lock, Wet Okole Seat Covers, Weathertech Mats, Husky Mud Flaps, 8000lbs Champion Winch/Winch Cradle and Quick Connect Kit, 4,500lbs Champion Winch/Front Hidden Winch Mount, OEM Painted Rims, Spidertrax 1.25, 265/70R17 BFG KO's
    I have a lower uniball gone, just got the Icon's before winter. Called icon and they said they won't pay for the uniball and they want $40+ for one, so is this what I need? If not what one and where can I get the best price? Thanks!
  7. Mar 11, 2012 at 2:13 PM
    rzimm001
    Bobby
    Wildomar
  8. Mar 11, 2012 at 2:41 PM
    Ryan07
    New Brunswick
  9. Jan 28, 2014 at 7:57 AM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    My passenger side is gone too... I haven't taken it apart yet but do these need to be pressed in and out and which one is needed exactly? ^^^
  10. Dec 7, 2014 at 12:11 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    subd because i need to order some of these
  11. Feb 8, 2016 at 9:39 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Bumping this thread, need a clarification, there are 2 different race widths in this link:
    http://www.summitracing.com/search/...er-in/0-6250-in/?autoview=SKU&keyword=Bearing
    FK WSSX-T/WSSX-TV Wide Series Spherical Bearings WSSX10T has a race width of 0.567 inches
    http://www.summitracing.com/parts/fkb-wssx10t/overview/
    FK FKS/FKSSX Precision Narrow Series Spherical Bearings FKSSX10T has a race width of 0.500 inches.
    http://www.summitracing.com/parts/fkb-fkssx10t/overview/
    I imagine that's a pretty important measurement in order to get the circlip/snap ring to seat correctly, can anyone definitively give an answer which will fit in an Icon coilover for a Tacoma?
  12. Jan 7, 2017 at 3:55 PM
    Laxtoy
    Maltby, WA
    Bumping this thread again-
    To clarify, it is the narrow race bearing. Made the mistake of buying the wide series and they don't fit.
    FYI, Sway-a-way 2.0 race runners are also the narrow series.
    https://m.summitracing.com/parts/fkb-fkssx10t
  13. Jan 7, 2017 at 4:02 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
  14. Jan 7, 2017 at 4:10 PM
    Laxtoy
    Maltby, WA
    Check your notes. I just physically verified on a 99 Tacoma by putting the offset spacers that line the lower heim where the lower strut bolt goes through and the wssx10t was too wide.
  15. Jan 7, 2017 at 4:43 PM
    Pickeledpigsfeet
    Foothills, CA
    Yep, you are correct.
  16. May 22, 2017 at 11:45 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What about this puppy?
    https://m.summitracing.com/parts/qa1-com10t
    I need to replace them in my Icon RR coilovers and thought COM10T is what I need. Kinda confused now with all the different products and prices...
    Edit: I have a 2010 in case it matters. And where do you get those snap rings, mine are shot
  17. May 24, 2017 at 1:23 PM
    TireFire
    Olympic Peninsula
    Bump, urgently need to buy but don't know which
  18. May 26, 2017 at 12:49 PM
    TireFire
    Olympic Peninsula
    Anyone????
  19. May 27, 2017 at 6:20 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    COM10T
    I prefer FK products but the QA1 will work.
    You can always call Icon and get a set with spiral locks direct from them.
  20. May 27, 2017 at 11:26 AM
    TireFire
    Olympic Peninsula
    If you want to get bent over and effed up the .... then sure, buy it from Icon lol.
    I actually measured the misalignment spacers last night and my race width seems to be 9/16".
    But where can I buy the snap rings??
