What size is the spare steelie?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachMX, Dec 14, 2013.
  1. Dec 14, 2013 at 7:36 PM
    ZachMX
    ZachMX [OP] Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Is it 16 or 15 inches? Thanks!
  2. Dec 14, 2013 at 7:45 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    16 x 7" if I'm not mistaken, but 16" for sure on a 6 lug.
  3. Dec 14, 2013 at 7:47 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Gotta be 16 or you'd screw up the transfer case possibly. It is 15 on the 5 lug, steel wheel
  4. Dec 14, 2013 at 7:58 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Stock spare is going to be the same size as your stock wheels. If you have 17" sport wheels stock, then your spare will be a 17" steel rim. If you have 16" OR wheels, then the spare will be 16" as well, and with the same stock tire. Make sense?
  5. Dec 14, 2013 at 8:28 PM
    ZachMX
    I figured, just wasnt sure, thought maybe a donut on there or something. Thanks, at work and its raining so didnt want to climb up under there right now.
  6. Dec 14, 2013 at 9:47 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    It's not that hard to lay under your truck and look?
  7. Dec 14, 2013 at 9:56 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    15" wheels don't fit on 6-lug trucks. ;)
  8. Dec 15, 2013 at 8:07 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Hmm, wasn't thinking about the sport 17", so yeah, what he said.
  9. Dec 15, 2013 at 5:14 PM
    ZachMX
    When there's snow outside, its now raining outside and your in uniform, not the best idea to lay on a dirty, snow covered asphalt parking lot.
  10. Dec 15, 2013 at 5:17 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    I thought the same thing but on my dads 2013 Sierra Denali it has 20" rims with a 18" spare. I thought that was messed up but his buddies ford has 20" wheels with a diff spare size also.
  11. Dec 15, 2013 at 5:31 PM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    So are they all the same if 16"? Width, style?
    What color are they, never thought to look, was going to use the tires on the spares for the wifes truck, have a 2011, 16" steel, and 2012 16" alloy.
    If the rims are the same as her steel and the grey color then I will not need to pull them, just program the TPS.
  12. Dec 15, 2013 at 5:33 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    The driveline only cares about the outside diameter of the tire, not the wheel size.
    I mean if you look at the overall sizing of the TRD OR tires versus the TRD Sport tires, they're identical, even if the wheel sizes are different. (265/70-16 vs 265/65-17). The overall radius of the tire is 15.3", and the overall diameter is 30.6". The SR5 uses a 245/75-16 which is 15.2"/30.5" respectively, which doesn't fall outside of the realm of tire wheel.
    I mean, you could conceivably run a 14" wheel on a Tacoma (neglecting brake clearance) with a 265/80-14 tire and be at 15.3"/30.7".
  13. Dec 15, 2013 at 5:36 PM
    Mr.Gadget
    NC
    True the normal 5 lug are 15" 2WD.
    But they are using smaller lighter, thinner tires and rims that may not match the rim size or width but the total height is the same so not as to mess up anything.
  14. Dec 15, 2013 at 5:36 PM
    Frkypunk
    Timmy
    Woods of P.A.
    They should be at that size, but double check the numbers on the side of the tire..for trucks that came factory with 20" tires there seems to be a difference in the spare size.
  15. Dec 15, 2013 at 5:38 PM
    Frkypunk
    Timmy
    Woods of P.A.
    I thought the same thing but on my fathers truck the overall diameter is no where close.
  16. Dec 15, 2013 at 5:56 PM
    Mr.Gadget
    NC
    You will only see that for a dealer instal tire option thing.
    They change all but the spare, I have run into that in the past.
    Past on a yota that had them, the spare was smaller factory and the tires were larger not much but 18" and plus 1 or 2....
  17. Dec 15, 2013 at 6:00 PM
    Frkypunk
    Timmy
    Woods of P.A.
    I agree...I think the real problem is you cannot put a tire that big under the box of the truck. It's the equivelent of hanging a 32 or 33 inch under our trucks...it just won't fit.
  18. Dec 15, 2013 at 6:05 PM
    ZachMX
    A 33 will fit under our trucks (2nd Gen) with slight modding of brackets. Just did it today, following others advice.
  19. Dec 15, 2013 at 6:08 PM
    Frkypunk
    Timmy
    Woods of P.A.
    I understand with mods it will fit ...but we are talking about a new factory truck.
  20. Dec 15, 2013 at 6:18 PM
    ZachMX
    Roger, gotcha.
