What size Metric or SAE fits that Bolt/Nut...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 45longcolt, Sep 17, 2013.
  1. Sep 17, 2013 at 7:10 PM
    45longcolt
    45longcolt [OP] Well-Known Member
    DFW Area
    2020 Off Road
    Back when I was turning wrenches every day I got to thinking there must be some relationship between Metric and SAE sizes. From experience most of us here know a 13mm wrench is very close to our 1/2" SAE in size. But there is an easy way to remember what size Metric and SAE are close to one another; Subtract (5) from the MM size and you get your answer in 1/16" SAE size.
    EXAMPLE:
    8mm- 5 = 3/16"
    9mm- 5 = 4/16" or 1/4"
    10mm-5 = 5/16"
    11mm- 5 = 6/16" or 3/8"
    12mm- 5 = 7/16"
    13mm- 5 = 8/16" or 1/2"
    Etc., I am sure it only holds out so far either direction but for the most popular sizes we use, it seems to work well. Just thought I would share that little tip with my Tacoma brothers. :)
  2. Sep 17, 2013 at 7:26 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    :D
    One size fits everything (kinda).
  3. Sep 17, 2013 at 7:31 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    10mm doesn't have an equivalent in Sae... i think. 3/8 is close but too small
  4. Sep 17, 2013 at 7:38 PM
    BamaToy1997
    Bill
    Navarre, FL
    I hate to burst the bubble here, but your numbers are off. You are really close, but in the real world, those wrench sizes are off a little. Over the years of turning wrenches, this is what I have found:
    8mm-5/16"
    10mm-3/8" BUT a 10mm will fit a 3/8, but a 3/8 will not fit a 10mm
    11mm-7/16"
    12mm- no match close enough
    13mm- 1/2"
    14mm- 9/16"
    15mm- close, but no standard wrench match
    16mm- 5/8"
    17mm- 11/16"
    18mm- Close, not close enough
    19mm- 3/4"
    20mm- close
    21mm- 13/16"
    22mm- 7/8"
    Good try though. You have great intentions.
  5. Sep 17, 2013 at 7:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Buy a metric socket set
  6. Sep 17, 2013 at 9:43 PM
    Chakraj
    Chakraj Well-Known Member
    CA
    2013 DCSB TRD SPORT v6 auto 4x4
    Badgers, I don't need no stinking Badgers.
    Dude it's a tacoma all you need is about 4 x 19mm, and you can basically rebuild the vehicle. You may need a 14 or 2 also.
  7. Sep 17, 2013 at 9:51 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    just multiply by 25.4
