What size plank fits in the bed slots?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JackedTaco, Jul 23, 2009.
  1. May 28, 2020 at 12:25 PM
    #41
    udelslayer
    udelslayer Well-Known Member
    North Carolina
    09 Taco 2wd 5AT
    I dont have a cap. If you pop 2x8's in there, whats the risk of them flying out of the bed? I want to secure them because it will be used for a fork mount bike rack head/adapter, but didn't want to drill into the bed liner. Is there a way to lock it down? I've seen a solo cup stay in a bed for years, but a brick just randomly flies out. Physics hates me. ....ok maybe somebody stole the brick lol.
    rayman54, BigRus75 and davidstacoma like this.
  2. May 28, 2020 at 1:26 PM
    #42
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    I pretty sure I saw pictures of someone using turnbuckles attached to d-rings at the bed mounts. The d-rings are a great mod anyway.
  3. May 28, 2020 at 2:25 PM
    #43
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Same, had to cut them down ad-hoc to get them to fit snuggly and level (notched an inch off).
  4. Jun 22, 2020 at 2:00 PM
    #44
    DTaco22
    DTaco22 Well-Known Member
    Darian
    17' Taco. TRD OR
    3" Eibach lift, JBA high caster upper control arms, 2" ToyTec add-a-leaf
    So what have you guys built to use the slots?
  5. Mar 17, 2022 at 11:55 AM
    #45
    Condor1912
    Condor1912 New Member
    2013 Tacoma 4x4
    Does anyone have an issue with the space between the 2x6 and the lip on the sides of the bed? The cut outs are only about an inch deap so the 2x6 suspends the rest of the plywood. About to pull the trigger on this set up
  6. Mar 17, 2022 at 12:35 PM
    #46
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    A 4x8 sheet of plywood or sheetrock will not span the entire width of the bed all the way to the lip on the sides of the bed. The plywood is only going to be supported by the 2x6 anyway. It's not an issue.
    If you are making a sleeping platform or some other kind of platform above the wheel wells, just notch the ends of the 2x6 so that they sit level with the lip on the sides of the bed.
    BigRus75 and Condor1912 like this.
  7. Mar 17, 2022 at 10:01 PM
    #47
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    I don't suppose you know off hand how much of the 2x6 needs to be notched to sit flush with the lip?
  8. Mar 17, 2022 at 10:18 PM
    #48
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Just so you all know @OZ-T has the skills, measurements and angles for the “perfect” fit.
    I saw the perfect fit he posted in some other thread a long time ago and it is indeed exact.
  9. Mar 17, 2022 at 11:01 PM
    #49
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  10. Mar 18, 2022 at 6:30 AM
    #50
    KeithB
    Keith
    Cheshire, CT
    Sorry, I don't. Just measure or looks like OZ-T has you covered.
  11. Mar 19, 2022 at 2:49 PM
    #51
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Simple, elegant idea and solution to address this need! I want to do this to my truck. So as not to assume, can you advise what you used for the bolt and washers? I'm assuming you drilled a hole and reached up and inserted it from the outside under there with a flat washer, then finished the set-up with the two nuts. My local ACE has a nice assortment of stainless hardware I like to use. I usually stick to a strict-policy of "no-drilling-new-holes" >anywhere< on my vehicles unless absolutely necessary, but I will for this mod. Thank you!
  12. Mar 19, 2022 at 4:26 PM
    #52
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Oof, I did that back in 2016 or so. I vaguely recall removing the tail light to get at the back side of the drilled hole. It does work nicely when I need some plywood or similar.
    Williston[QUOTED] likes this.
  13. Mar 19, 2022 at 5:44 PM
    #53
    Williston
    New England
    Not a problem guy! "removed the taillight": That's all I need to know! Thanks! I'll figure out the rest. They let me try the hardware out (fit for that cable end-piece) before making me pay so I'll figure it out. Right now I'm using chains and the carabiner solution. It works but it rattles some and gets in its own way sometimes when closing the gate. Again: much thanks for posting that with the pics.
    vssman[QUOTED] likes this.
