What size Procomp 7089's?
Discussion in 'Wheels & Tires' started by schmittuml, Dec 7, 2009.
  1. Dec 7, 2009 at 4:09 PM
    schmittuml
    schmittuml [OP] Member
    Brian
    Mass.
    2009 DC LB Sport 4WD Magnetic Grey Metallic
    Hey guys,
    I tried searching a bit but it is kind of urgent after an accident that I grab some new wheels and tires. I am looking to get the Goodyear Wrangler Duratracs on 7089's, just wondering what size rim to get (bolt pattern is confusing?).
    I am either gettin 265/70R/17 or 285/70R/17 for tires. will there be any rubbing on either setup WITHOUT a lift? I am putting in a toytec lift as well, but wondering if I can get away with the setup for a week without a lift. Rubbing issues?
    Thanks in advance....I know it is a rushed question, but I cant drive my Tacoma until I get this squared away..
  2. Dec 7, 2009 at 4:14 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    with no lift you will rub the 285.
    for a bolt pattern our trucks use a 6x5.5 so 6 lugs on a 5.5" diameter circle
  3. Dec 7, 2009 at 5:49 PM
    goride
    goride Well-Known Member
    Josh
    UTAH
    09 trd sport dbl cab lb
    Tinted windows,Upgraded stereo system,satoshi grill with piaa lights behind,dash light color mod to blue,mag light holder,OME dakar leafs,Toytec ultimate lift,LR uca's, BFG AT's 285/70/17 on Pro Comp 7089s,weather techs, leer shell,CBI sliders and rear bumper w/tire gate,soon DTLT w/ wicked flow catback exhaust
    What he said,also make sure on the wheels that you order the non-hub centric ,the hub centric are not correct.If you are getting a 3 in lift I would recommend waiting and getting the 285/70/17's . Good luck:D
  4. Dec 7, 2009 at 7:17 PM
    schmittuml
    Brian
    Mass.
    before I continue, can I go on record that this is why I love this place. I am sure this is stuff that could be searched for and dug through. I have had a rough couple of days....ended up getting extremely cut-off on the highway in new england's first snowstorm, spun around twice and smacked the front right against a guardrail, bounced hit the back end of the truck and bounced back into traffic. By some MIRACLE i have not a scratch, there is not a scratch on the body of the truck, but the wheels and tires got f'ed up. Blessing in disguise, it moved forward the wheels/tires/lift i was planning.
    Anywhere else I would get flamed and called a noob or a wook or a jong and told search function for an answer. Mreimann and Goride , i appreciate just the honest answer without flaming.
    I think I am going to go with the 285/70/17's - what size rim do I need, the 17X8??
  5. Dec 7, 2009 at 7:28 PM
    goride
    Josh
    UTAH
    Thats what size I went , i believe they are 17 x 8 with 4.5 back space,remember order the non-hub centric. Like was said thou you will rub w/o lift and maybe on the plastic in the fender which can be trimmed.
  6. Dec 7, 2009 at 7:41 PM
    LoHoNas
    LoHoNas Well-Known Member
    Jeff
    Lake Jackson TX.
    09 4x4 DC TRDSPORT MGM
    Debadged, Fog light mod,Grillcraft, Icons,TC UCA's, OME dakar leaf pack,Procomp 7089,BFG KM2 285/70/17 JVC NAV
    If your getting the lift than the 285's will be good. I'm not sure how much rub you will get when its stock but it will prob rub on the cab mounts and possibly on the upper control arms too. Get your lift quick if you go with the 285's. If you get 265's and the lift you will regret it , and want the bigger tires. Just my 2 cents:rolleyes: Nice choice on the wheels:thumbsup:
  7. Dec 7, 2009 at 7:44 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    ^^^X2^^^
  8. Dec 7, 2009 at 7:52 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    like hands down just looking at the bed of your truck soo sexy. you wanna trade:)
  9. Dec 7, 2009 at 8:29 PM
    mreimann
    Denver, CO
    you don't have to go w/ 285's. more than likely they will still rub even with a lift. if you don't care about trimming then the 285's will do great, but if you don't wanna trim then 265's are the lazy way out.
    but they might look a little small on a lifted truck
  10. Dec 7, 2009 at 9:19 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    Thanks bro.......I like your long bed, maybe if you painted it MGM and, uh....never mind that won't work:p
    This is true..... the 285's will still rub with 3 inches of lift. But all you have to do is trim the plastic in the fwd wheel wells. It's easy and you can't tell unless you stick your head in there:D
  11. Aug 13, 2010 at 3:03 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Fife, Wa
    05 PreRunner TRDsport
    TRD Cold air TRD Cat-back
    why does jcwhitney website says the procomp 7089 are not compatible with our trucks? is it because they're refering to hub centric? anyone know where i can get a brand set in 17" for a good deal?
  12. Aug 13, 2010 at 2:44 PM
    camh
    camh Member
    Cam
    D.C
    05 SR5
    Hey man I love your truck!!
    what kind of lift do u run??
  13. Aug 13, 2010 at 2:51 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    might i suggest looking on 4wheelparts for the pro comp stuff , i know when i bought mine for my old ranger they had buy 3 get one free on tires/wheels, made my 7089//extreme AT an even better deal
  14. Aug 13, 2010 at 7:34 PM
    Archangel
    Archangel Discount Tire Company
    Charlotte, NC
    13 Malibu LT
    Go to Discount Tire during the last weekend in August during Tax Free weekend, and you'll save yourself a shit ton of money
  15. Aug 14, 2010 at 12:56 AM
    TRDsport253
    Fife, Wa
    If this is not BS i will do that.
  16. Aug 14, 2010 at 3:59 AM
    Archangel
    Charlotte, NC
    13 Malibu LT
    NC is having a Tax-free weekend the last weekend in August, and I'm pretty sure the rest of the stores in the company are too
