What size rear spacers for +3.5" front?
Discussion in 'Long Travel Suspension' started by soggyBottom, Aug 30, 2023.
  1. Aug 30, 2023 at 2:15 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I've seen a few people with +3.5 on the front only use 2" on the rear. Is there a reason why I shouldn't have super thick spacers on the rear?
  2. Aug 30, 2023 at 2:18 PM
    zcweisman
    zcweisman Well-Known Member
    Zach
    San Diego
    2016 TRD Off-Road 4x4 MGM, 1993 FZJ80 Land Cruiser
    TRD CAI Magnaflow Catback Exhaust - Chopped OVTune 2.0 Beta 25600 91 Nitro 5.29 Gears TRD Pro Grill Raptor Lights Mod Hondo Vent Mount Hondo Radio Knobs Cobra 75 CB Radio Firestik 3' Antenna Gobi Ranger Rack Leitner Designs ACS Classic SwitchPro 9100 Baja Designs S8 30" Baja Designs Squadron Sport Amber Driving/Combo x2 Baja Designs Squadron Sport Amber Wide Cornering x2 (fogs) Baja Designs Squadron Sport Spot Ditch Lights x2 Baja Designs S2 in backup light positions (scene) x2 Baja Designs S1 (scene) x2 KC Hilites Chase Bar SCS F5 Matte Bronze 17x8.5 Nitto Ridge Grapplers 285/70r17 LR E Tepui Autana 3 FOX 2.5 RR Front and Rear 700lb, 14" Eibach Springs Dakar leaf springs + 2 AAL C4 Hybrid Bumper C4 Sliders C4 HC Rear Bumper w/Swingout RCI Full Steel Skid Plates Recovery: VIAIR 400P Compressor Smittybilt 9K Gen3 Winch Maxtrax 48" Hilift Shovel Assorted straps
    Go with high offset wheels that have a super low negative backspacing. SCS F5s are a good option to have the wheels stick out without using spacers. Otherwise don't use anything wider than a 1.25" spacer. Coming from a guy with +4 LT.
    soggyBottom[OP] likes this.
  3. Aug 30, 2023 at 2:19 PM
    soggyBottom
    Are you using different wheels on the rear vs front?
  4. Aug 30, 2023 at 2:21 PM
    zcweisman
    Zach
    San Diego
    Nah, same all around. I'm actually selling them as I just got beadlocks, and a new 6" I think wider rear end.
  5. Aug 30, 2023 at 2:32 PM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    Davis
    Cave Creek, AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    I have +4.5" LT and run the same 0 offset wheel all 4 corners. No spacers in the front, 2" spacer in the rear.
  6. Aug 30, 2023 at 6:19 PM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    +3.5lt right now. No spacers in the rear, but hopefully putting in a 69" wide rear end soon so itll look a little better.
  7. Aug 30, 2023 at 7:53 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    2" is common for 2nd gens
  8. Aug 31, 2023 at 10:27 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I have a 2nd gen Tacoma with Camburg 3.5" LT. I went from 1.50" rear adapters to 2" and now back to 1.25".
  9. Sep 3, 2023 at 11:18 AM
    soggyBottom
    Why the change back to 1.25"?
  10. Sep 5, 2023 at 9:59 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    It started to look a little too aggressive for me. Maybe I'm getting too old o_O.
  11. Sep 5, 2023 at 10:09 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    It will depend on what look and performance you want. Often, pre-running folks like the rear to be a tad narrower. Many folks set up the rear to be the same front and rear for mix use. I have a +2 kit with high-offset wheels, and my rear is super narrow to the front ( for me at least ). I have a 69" Tundra rear end on order and plan to go with lower offset wheels.
    I sent high-offset wheels before the LT kit, avoiding spacers for my rear kit and front bypass setup.
    A Wider axle is the best way to go about it but at a higher cost. I bent my rear axle, so the time to do it came up. Replace or upgrade.
