What size sockets and wrenches for working on a Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Mar 27, 2016.
  1. Jan 31, 2020 at 11:49 AM
    #41
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    I was just about to say, I used to use the adapter with the breaker bar but after like the 3rd one I broke I stopped doing that.
    I also seem to crack stubborn bolts free more consistently without the adapter, I think it adds some flex give in there... but might just be in my head.
  2. Jan 31, 2020 at 12:11 PM
    #42
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Pretty much all my jobs have been done exclusively with 2" and 6" 3/8 drive extensions, and even numbered metric. 10, 12, and 14mm are the overwhelming majority. 16, 17, or 18mm might come in for larger repairs like the steering rack...but that's not a road/trail repair. My recommendation is at least a set of metric deep and standard sockets, ratcheting wrenches, and 2 large adjustable crescent wrenches (tie rod or alignment bolt adjustment).
    You obviously need a torque wrench (but maybe not for emergency repairs), breaker bar (used every time for the wheels), and some 3/8-1/2 adapters. I use an old 12" section of copper pipe as an extension.
    So basically your list looks tentatively good to me. +Maybe a set of screwdrivers.
    I believe I have a 21mm for mine (6 lugs, though I'd be surprised if 5s were different)
    Dufus[QUOTED] likes this.
  3. Feb 1, 2020 at 9:48 PM
    #43
    Dufus
    Dufus Well-Known Member
    Located in Colorado
    99 Taco 3.4L manual 4x4 SR5 - Imperial Jade Mica
    Mods: bent frame and sun weathered roof paint.
    This reminds me...some heavy gage wire that you can bend around stuff...this has gotten me off the trails more than once.
  4. Feb 2, 2020 at 2:43 AM
    #44
    Matermax
    Matermax Well-Known Member
    Nathan
    NE Arizona
    1999 Tacoma TRD
    White Line LCA bushings.
    8, 10, 12, 14, 15, 17, 19, 21. Seems like I rarely use a 13, 16, or 18
  5. Feb 2, 2020 at 3:24 AM
    #45
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Every joint takes torque from the socket.
    If you have 5 extensions that is 10 joints trying to break loose the top bell housing bolts it is almost impossible .
  6. Feb 2, 2020 at 7:16 AM
    #46
    latchlock8111
    latchlock8111 Well-Known Member
    ... cheep ones all the time in the work truck. When I loan out tools I don't have to stick around to babysit. Keep it , its yours ... many times I have loaned out the good ones ... Snap-On ... Mac ... never to see them again. The good-heavy duty jumper cables, I do stick around to get them back, as it's me that is normally still connected to one end ...
  7. Feb 2, 2020 at 8:19 AM
    #47
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    I actually really like my Quinn brand 1/2” drive sockets from harbor freight.
    Dufus likes this.
  8. Feb 3, 2020 at 9:01 AM
    #48
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yeah, you can't wrap duct tape or tip ties around an exhaust that's falling off. Need some bailing wire for that.
  9. Feb 3, 2020 at 9:06 AM
    #49
    Dufus
    Located in Colorado
    Exactly, sometimes you need a heavy duty quick fix where tape and zip ties won't work.
  10. Feb 3, 2020 at 9:21 AM
    #50
    puddle
    puddle Well-Known Member
    Kris
    ID
    2020 TRD OR
    Cool dealer placard
    Add some Misc lengths & gauge of wire & butt connectors, ya know, for when your dad breaks both rear shock mounts on his Jeep and bottoms out cutting fuel pump wires in the middle of the Mojave trail.........Just saying
  11. Feb 3, 2020 at 9:22 AM
    #51
    Dufus
    Located in Colorado
    :yes: What he said
