What size speaker for 98 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98tacojunky, Dec 22, 2017.
  1. Dec 22, 2017 at 2:14 PM
    98tacojunky
    98tacojunky [OP] Well-Known Member
    Upstate NY
    2019 TRDOR double cab
    i have a 98 tacoma sr5 4cyl 4x4 I’m wanting to swap out the speakers as 2 aren’t working. There is an aftermarket head unit in the truck already and The speakers seem to be original. At least the tears are for sure. What siZe speakers do these trucks need? I’ve done some research and some people say they come with 6x8 or 5x7. What do they come with and what works for them? I don’t want to do any trimming or anything. I just want to be able to mount them in.
  2. Dec 22, 2017 at 2:15 PM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Mine are 6x1/2
  3. Dec 22, 2017 at 2:18 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  4. Dec 22, 2017 at 2:47 PM
    98tacojunky
    Upstate NY
    Crutch field lists 5.25 speakers on there website with a bracket. 6.5 with trimming but they don’t list any 6x8 or anything. I may not buy from crutchfield therefore I’m trying to figure out if there is a size where I don’t need a bracket or anything
  5. Dec 22, 2017 at 7:16 PM
    98tacojunky
    Upstate NY
  6. Dec 22, 2017 at 7:25 PM
    Madjik_Man
    Colorado Front Range
    Did you plug your truck specs into crutchfield? It will give you options of direct fit and "modification needed" fits.
    FYI I put Polk 6.5" slim in my 1998 and it was a direct fit with the supplied bracket.
  7. Dec 23, 2017 at 5:13 AM
    98tacojunky
    Upstate NY
    Yes I plugged it in that’s where I got the information that the 5.25 will fit with a bracket and the 6.5 required cutting and trimming. But I’m trying to figure out if the 5.25 fit without a bracket or if a different size does because I might not buy them from crutchfield therefore I won’t get the bracket
  8. Dec 23, 2017 at 7:47 AM
    Madjik_Man
    The 6.5 I bought did not require cutting or trimming. There are many options out there that do not. See the two pictures below. First one is stock speakers, second one is the 6.5s I put in. You could theoretically use the stock bracket and just screw the new speakers into it.
    And FWIW, since you're going to be opening up the doors/removing the door panel, you might as well do some sound deadening in the doors. You can buy the most expensive speakers and they still won't sound great if they're mounted onto a very resonant steel drum.
    Pervy likes this.
  9. Dec 23, 2017 at 7:53 AM
    Madjik_Man
  10. Dec 23, 2017 at 10:49 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Through some old speakers out of my duramax in my taco. Fit no problem, they were 6.5"
  11. Dec 24, 2017 at 6:51 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    6.5" all around like others have said. Just make sure you get slim ones for the front, close to 2" mounting depth or they won't clear the window track.
  12. Dec 24, 2017 at 7:18 AM
    98tacojunky
    Upstate NY
    Thanks guys
  13. Dec 24, 2017 at 8:56 AM
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    I went with slim line 6.5" and did some sound deadened too like these guys suggested.
    Pervy, 03 NIGHT TACO and The Driver like this.
  14. Dec 24, 2017 at 9:03 AM
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
    That sound deadened looks good. Did you do any on the inside?
  15. Dec 24, 2017 at 9:10 AM
    rybern
    N Alabama
    Thanks. I put one layer on as much of the inside of the outer door skin as I could. Door is more solid and road noise is reduced. I had a pretty large roll of the stuff(Rammat) from an install I did a few years ago. I went a bit further than what most folks will go(but not near as far as others).
    If I had it to do over again, I would have used a this piece of sheet metal on the large opening to give it some support.
  16. Dec 24, 2017 at 9:17 AM
    zbadboy
    Arizona
    Palomino Camper
    Looks Clean.
  17. Dec 24, 2017 at 9:22 AM
    rybern
    N Alabama
    Thanks again. I didn't just slap it up there. LOL. I also had very little waste. Smaller pieces are easier to work with and help minimize waste too.
    Geneyota likes this.
  18. Feb 24, 2019 at 5:24 PM
    panardo
    panardo Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    And what about the rear ones, does anybody have the right size for the rear ones on an extended cab?
    Chadley22 likes this.
  19. Feb 24, 2019 at 6:12 PM
    rybern
    N Alabama
    I don't remember. I looked into putting 8's back there but never did. Mine sounds pretty darn good like it is.... components up front and stock rears off Pioneer HU power.
