What size speakers for sub box?
Discussion in 'Audio & Video' started by Whitetaco4x413189, Jun 22, 2023.
  1. Jun 22, 2023 at 4:16 PM
    Whitetaco4x413189
    Whitetaco4x413189 [OP] Member
    2017 Tacoma
    I am looking to put subs in my truck and don’t know what I’m looking for what size speakers should I use and a reasonable price.
  2. Jun 22, 2023 at 4:49 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    It depends how much of a heavy hitter you are .
    I have one 10 on the passenger side and it sounds really good .
    Mr marv makes good stuff to put your own sub . JL Audio makes some nice stuff also
    I have a 4 door
    Extended cab if you don’t mind using one side on the floor a nice regular box sealed with a good sub works fine
    But again if you want serious bass then sky is the limit
  3. Jun 23, 2023 at 8:05 PM
    Whitetaco4x413189
    2017 Tacoma
    I’m just looking for something to put behind my seat in the back maybe like 2 10” or 12” idk what would be better if you can fit 12’s?
  4. Jun 24, 2023 at 3:53 AM
    TruckGuy63
    Gilbert
    New York
    If you go with JL audio they actually make a self powered 8 that will fit in the cubby.Or you can get a stealth box from them. If you do the stealth box you need an amp. The first one you don’t .The other way is to get a pre made or custom box and then put your own sub and amp . Anther option is to look into oem audio . They have a speaker system for our trucks that is plug and play
  5. Jun 24, 2023 at 11:38 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I've got an 8" underseat Powered Sub that kicks pretty good a$$. Spliced from my rear speakers, behind the HU.
    Pretty impressed how much bass I got from so little space.
  6. Jun 25, 2023 at 6:28 AM
    TacoStarv
    TacoStarv Well-Known Member
    New Jersey
    2020 Black Tacoma SR
    Which one did you get?
  7. Jul 3, 2023 at 6:43 AM
    Nuked
    Nuked Active Member
    Morgantown, WV
    2020 TRD OR DCSB 4x4
    I have a single 12" behind the seat of my DCSB. If I had to do it all over I would have went with a single 10".
  8. Jul 3, 2023 at 7:08 AM
    TruckGuy63
    Gilbert
    New York
    10 ‘s are nice because they produce tighter bass than a 12 sometimes. My last truck extended cab, I had two 10’s with a Alpine amp set up at 2 ohms about 600 watts and it was pretty impressive. Polk separates up front and 6 in coax in rear . Probably one of the cleanest systems I’ve owned in a long time . Not super loud but really clean and tight.
