What size tire for a 2.5 inch ICON lift
Discussion in 'Wheels & Tires' started by YotaDave, Jul 28, 2012.
  1. Jul 28, 2012 at 2:02 PM
    YotaDave
    YotaDave [OP] Member
    Dave
    Middletown PA
    2012 Tacoma 4x4
    HID's for right now an a double din. ICON coilovers with ICON AAL an ICON rear shocks. Nitto A/T with KMC XD wheels
    Looking to install the ICON stage 1 on my Tacoma, right now it has 245/75/16 a few years back i picked up a set of KMC wheels that are 17x9 so since i'm going up in wheel an tire size should with only 2.5 inch of lift should i go with a 285/65/17 or a 275/70/17 Any help would be great, Thanks!!
  2. Jul 28, 2012 at 6:46 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    285/70/17 with some trimming and a possible cab mount chop, 275/70/17 with possible trimming, 265/70/17 with no trimming.
  3. Jul 28, 2012 at 6:47 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
  4. Jul 29, 2012 at 8:13 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    Thanks KPT, i'm thinking along the lines of the 265/70/17 i just seen a post of a guys rig with a 3inch ready lift an that's what he was running so def perfect for 2.5 inch. Thanks for the input
  5. Jul 29, 2012 at 10:14 AM
    KPT
    09 Prerunner
    Make sure the tires you choose are approved for 9" wide wheels. A lot of 265s aren't, you can find out on the manufacturers website.
  6. Jul 29, 2012 at 10:19 AM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    no mods until the warranty is up!
    Ive got danohoes (ICON) set @ 2.5 and im running 285/70/17's click on my sig, ive got a ton of pics in my build thread....
  7. Jul 29, 2012 at 10:29 AM
    macampos50
    macampos50 Well-Known Member
    mike
    san diego, ca
    new beast- 7-2012
    Bilstein 5100's all 4 corners, Drop in K&N, Interior LED, rear LED, reverse HID breaklights, turn signal LED and HID's by CSjumper2003, Cab Chop by Socalduckslayer, TC UCA's, wicked flow 13", ammo can mod, fog light mod, A little pastidip Everywhere Goals: AAL by 4WD, intake, pulleys? Spacers? maybe a power chip?
    Spend the extra money on the taller tires, the AAL and the cab chop you'll be happy and never look back.
  8. Jul 29, 2012 at 10:33 AM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    OP,
    it looks like you have the 2.7L engine??
    i have 265/70-17's on right now (i had 245/75-16's before) and it made my truck a little more sluggish. Thats something to keep in mind when your going to even bigger tires.
  9. Jul 29, 2012 at 11:24 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    thanks for the tip Spencer! I'll do that KPT Thanks!
  10. Jul 29, 2012 at 11:26 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    Nice rig Brett!!
  11. Jul 29, 2012 at 11:28 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    One thing i'm trying to stay away from is cutting anything out from my inter fender wells i don't mind if i have some wheel well showing, same that it def not as much as the 245's are going to show tho lol
  12. Jul 29, 2012 at 11:30 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    Spencer, how wide of a wheel are you running? are the 17x9?
  13. Jul 30, 2012 at 7:14 PM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    sorry for not responding sooner! and yea there 17x9
  14. Jul 31, 2012 at 4:37 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    No problem! ok thats what i have here 17x9. You don't have any trouble with them? I was thinking that i would have to go with a 275x60 or 65 with them. Whats your offset? My worry is to buy tires an the wheels not fit the tire right or that my -12mm offset will mess things up also.
  15. Aug 1, 2012 at 1:28 AM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    i don't know the offset, but they are 4.5" of backspacing for the spindle lift that i got. but with a 265 the tires look a little stretched on the rim. but no problems with them at all
  16. Aug 1, 2012 at 5:20 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    Awesome! If i was reading a chart right the -12mm offset is 4.5 back spacing. I took one of the wheels with me to work last night an mounted on with out a tire since i don't have them yet an everything looks like it will work out well! The Nitto's i'm looking at looking at the website is saying the tires will fit from 7.0, 8.0, an a 9.0 in wheel with so i'm going to give them a shot an see whats up! Thanks again ya'll for your help an input! Nice looking truck Spencer, I like them wheels!
  17. Aug 1, 2012 at 8:56 PM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    hey , just fyi, with the backspacing the tires will rub in the front! i got that backspacing because i lifted my truck and the spindles required that backspacing. and thanks :D i have to give my uncle credit for these because he owns the company :cool:
  18. Aug 2, 2012 at 8:47 AM
    YotaDave
    Dave
    Middletown PA
    2012 Tacoma 4x4
    ok cool thanks! I'll found out here soon my tires coilovers an all will be here tomorrow! Lucky!! lol
  19. Aug 2, 2012 at 11:27 AM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    You should be fine then, After my lift they only rub when I'm backing out of a driveway at almost full turn
