What size tire/rim for smoothest ride?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AchillesWheel, Nov 29, 2021.
  1. Nov 29, 2021 at 3:03 PM
    AchillesWheel
    AchillesWheel [OP] Member
    2001 prerunner xtracab
    The 2001 Prerunner I just bought came with 17 inch 265/65/R17 Pathfinder all-terrain tires which seem to give a significantly looser, rougher feeling drive than my previous 93' truck. Per the sticker on the door jam, O.E. on the Prerunner was 225/75/15. I'm not an off-roader so I don't need all terrain tires. My neighbor says a 16" rim might give a better ride than a 15" but what I read online suggests smaller rim generally provides smoother ride. I would appreciate any advice/feedback --including brand suggestions--from those of you more knowledgeable than myself. (That's most of you:)
  2. Nov 29, 2021 at 3:16 PM
    Glamisman
    Glamisman Well-Known Member
    if possible look at the calipers before you go smaller on the rims. There is a popular modification where people put the larger Tundra brake calipers on Tacomas and this requires a larger rim. There are a series of numbers on the Tundra calipers that ID them as Tundra calipers. As to your question, cant go wrong with Michelins for the tire, quite, smooth ride but price wise...
  3. Nov 29, 2021 at 4:14 PM
    AchillesWheel
    Thanks, Glamisman!
  4. Nov 29, 2021 at 4:21 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    go into local tyre store
    compare 1 size against the other.....................side by side
    more sidewall usually results in smoother ride
    remember its a truck..............salesman said when i bought my PreRunner
    ‘ Drives like a car ‘ !!!!! true dat
    My SR doesnt weigh as much.....rides a little choppy
    its a TRUCK
  5. Nov 29, 2021 at 4:29 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    My 2004 prerunner came with 265/70/16s. It's not the rim size. Just get some tires that look like car tires in that size and it'll be a lot smoother then all terrains.
  6. Nov 29, 2021 at 4:34 PM
    Bishop84
    Bishop84 Well-Known Member
    Smallest rim means more tire, which means smoother ride. The tire is able to absorb shock along with the suspension.
    That said 15-16 isn't a huge difference.
    I'm always a fan of running the smallest rim and thickest tire I can, that way the tire can absorb shock along with the suspension.
    I would run 225/75R15 with a street tire. Hakook Kinergy ST is a simple choice.
    Alternatively you can run 235/75R15, this is a hair larger than stock in diameter but gives waaaaay more choices, including the coveted Michelin LTX tire. Will likely look better.
  7. Nov 29, 2021 at 4:37 PM
    AbbyNormal
    AbbyNormal Active Member
    99 4x4 extended taco
    tundra brakes, more to come..
    I'm installing 16's on mine since I'm doing the tundra brakes, Have 15's with brand new tires that I'm looking to get rid of.
    AchillesWheel[OP] likes this.
  8. Nov 29, 2021 at 4:52 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    An engineering rep from Uniroyal (during an 18 wheeler braking test several years ago) told me that roughly 1/2 of the suspension of the truck was due to sidewall flex. My Taco came with 18 inch wheels - 30.5 diameter and after a change to a 32 inch tire the ride definitely was improved.
  9. Nov 29, 2021 at 5:28 PM
    AchillesWheel
    Thanks, all for the info. AbbyNormal where are you--I am in Boulder, CO.
  10. Nov 29, 2021 at 7:49 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    What's your tire pressure? Are you running the recommended pressure in the door jamb? And are your shocks in good shape?
  11. Nov 30, 2021 at 5:17 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Stay away from all terrain, load E LT tires. Make sure you use a p metric highway tire.
  12. Nov 30, 2021 at 5:29 AM
    AbbyNormal
    Poplarville Ms.
  13. Nov 30, 2021 at 8:19 AM
    AchillesWheel
    Abby-Sorry you're not closer--I would have been interested in your rims/tires. Oh well---cheers!:)
