What size tire?
Discussion in '1st Gen. Tacomas (1995-2004)' started by baker_adam543, May 21, 2009.
  1. May 21, 2009 at 3:38 PM
    baker_adam543
    baker_adam543 [OP] Member
    04 Taco 4x4 5 Speed
    Yeah, so i have an 04 xtra cab 4x4 3.4L and i just bought a 3 inch toytec lift and i was just wondering if 285/75 R16 would fit without rubbing at all. And if they do, wha would I have to do to get them to not rub and what size is the biggest I could run? Thanks
  2. May 21, 2009 at 3:39 PM
    baker_adam543
    04 Taco 4x4 5 Speed
    BF Goodrich Mud Terrains KM2's by the way
  3. May 21, 2009 at 4:08 PM
    Showtime250
    Showtime250 Bryon
    St. Albans WV
    2003 Tacoma 2.7 4x4
    Toytec 3 inch suspension lift, Mickey T wheels, BFG MT's, weston bull bar and step bars, and aftermarket stereo
    I recently added a toytec lift too. Yeh you should be able to clear those if not there is a pinch weld on the bottom of ur fender located by the mudflap. It is covered by a protruding piece of plastic. This is where your only rub should occur. You can take a utility knife and cut the plastic away and then take a hammer and pound that pinch weld flat. This should take care of your problems. I put 33 12.50s on mine yesterday with no rub at all but the wheels didnt fit.
  4. May 21, 2009 at 4:17 PM
    baker_adam543
    04 Taco 4x4 5 Speed
    Yeah Ill try it thanks. Wha size lift did u put in?
  5. May 21, 2009 at 5:25 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    With 285's youll rub on full turns on the frame, i would get a wheel with a 4" backspace or less
  6. May 21, 2009 at 5:26 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
