what size tires can I run?
Discussion in 'Suspension' started by 02TACOMA, Apr 21, 2009.
  1. Apr 21, 2009 at 5:22 PM
    02TACOMA
    02TACOMA [OP] Member
    Reidsville NC
    tacoma TRD 4x4
    magnaflow exhaust,cold air intake
    I'm thinking of getting a 4" lift can a run 33-12.50 tires without any rubbing? And do they make a 33-12.50 for a 16" rim? I would like to run 15" wheels but I read on here that you can't because of brakes.
  2. Apr 23, 2009 at 9:17 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    on a 4" drop bracket, you can run 305-70-16 comfortably...
    you can can also run a 315-75-16 but regearing would be a must...
  3. Apr 23, 2009 at 9:22 PM
    dabighi
    dabighi Well-Known Member
    33s no prob.just watch the 16s tho.most dont clear the spindles.only true fire method is to have the place installing them test fit em rotate and check for adequate clearance.
  4. Apr 23, 2009 at 9:24 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    his screenname says 02Tacoma, so assuming his truck is like his sn, then he can clear 15s and 16s...
