What size tires will fit my truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fatherof2, Sep 2, 2015.
  1. Sep 2, 2015 at 3:58 AM
    Fatherof2
    Fatherof2 [OP] Well-Known Member
    Massachusetts
    2004 DC TRD
    Hi Gang,
    I have an 04 4DR TRD V6 that has 265 70R 16's on it. It is 100% stock.
    I am going to need new tires in the not too distant future.
    I would like to go with BF Goodrich AT's.
    I have been looking on Craigslist and I NEVER see this size for sale.
    Are there other sizes that will fit my truck with zero rubbing?
    Thank you!
  2. Sep 2, 2015 at 4:09 AM
    reef
    reef Well-Known Member
    04 4WD
    I just got new BFG KO2 265/75/16 I love them.
  3. Sep 2, 2015 at 4:24 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
  4. Sep 2, 2015 at 9:09 AM
    CrawfishTaco
    CrawfishTaco Alright, alright, alright
    Zack
    West Central Texas
    2002 4x4 2.7L 5spd SR5 Xtra cab
    I have a set of 4 in my garage you could get cheap if you're in Texas
  5. Sep 2, 2015 at 10:43 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is that an aftermarket shackle I see? How much and what kind of lift are you running?
  6. Sep 2, 2015 at 11:28 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
    So my only option is really the 265/70R/16?
    Will I get rubbing with anything else?
  7. Sep 2, 2015 at 12:46 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    That is the largest tire you can run on a stock 2004 Taco TRD without rubbing...
    I am running 265/70/17 as I am using the very common 2nd gen 17" alloy's, very slight rubbing at full lock, but with 3/4" Bora hubcentric spacers spacers, perfect...
  8. Sep 2, 2015 at 1:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    In general, these trucks can run 32" tall tires on stock alloy wheels without rubbing. However, so many factors come into play when you are asking the question, "will they rub?"
    For example, how old are your coil springs in front? Have they lost any of their lifting ability? And how you use your truck is a factor. If the only flexing the truck sees is from speed bumps and your front end isn't starting to sag a bit, then 32s may be fine. However, if you use the truck off road, you may quickly find that you get unexpected rubbing.
  9. Sep 2, 2015 at 3:05 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    as they stated, if you're stock and the truck is a street queen, the 265/75-16 will work fine. you will hear a little rub when turning fully to one side or occasionally when backing up if you hit bumps/dips
    also the BF Goodrich are just "ok" tires anymore. too expensive for not as good tread-wear/tread-pattern :(
  10. Sep 2, 2015 at 3:39 PM
    reef
    04 4WD
    Yup it is. I'm running the daystar 2.5 inch leveling kit. went in nice and truck runs great! the bigger tires make everything better also
